08-15-2008, 04:24 AM | #1 |
Pebble Pounder Join Date: Jul 2008 Location: Australia
| Crawler design Ideals
While in the building stage I often wonder, what are the "Ideals" that i'm trying to work towards? It effects all my decisions all the way through the build. So far i'm thinking (but not sure on) -minimum centre of gravity -maximum ground clearance -minimum weight ?? -maximum steering angle -Front - Rear weight distribution?? -Articulation?? -minimum axle steer -maximum available torque -maximum available wheel speed If I knew the ideals I'd know which way to go when building things. |
08-15-2008, 09:34 PM | #2 |
Newbie Join Date: Jul 2008 Location: Waynesboro
it sounds like if you can make a build with all of those you mentioned then you would have a unbeatable rig. but im not sure what your getting at or asking here.
08-16-2008, 03:38 PM | #3 |
Rock Crawler Join Date: Jul 2008 Location: Dutch Oven - AZ
| My answer will be of no use to you at all. I think... Ultimately, its your call. All that you mentioned is great, however, everything on your list affects everything else and has to work harmoniously. Its all give and take. For example: High ground clearance means you'll get hung up less, but can increase your torque twist. Softer tire foams can wrap around rocks better, but your axle may hang up more. My AX10 is configured very closely to my buddy's but for some reason his crawls best with all 4 wheels weighted the same, where mine likes more weight up front. I have no clue why? Your personal driving style will give you the answers much better than anyones feedback. |
08-16-2008, 04:57 PM | #4 |
Rock Crawler Join Date: Apr 2006 Location: Eau Claire
Your best bet is to come as close as possible to all of the things you are shooting for and drive the heck out of it. You are probably find out that a lot of things you want will not fit your driving style. The big thing with this end of the RC hobby it to keep experimenting, and testing. It never ends if you want the "perfect" rig for you.....
08-25-2008, 04:12 AM | #5 | |||
Your comment about the front/rear weight of the ax10's is interesting. some guys have the wheels weighted evenly and some use delrin rears and weighted alu fronts looking for max front/rear weight ratio?? I'm still not really sure on that one. Quote:
08-25-2008, 09:18 AM | #6 |
Rock Crawler Join Date: Aug 2008 Location: Strugglin
| jduke31+6
QUOTE" Your personal driving style will give you the answers much better than anyones feedback. well said Mr duke |
