08-23-2008, 08:56 PM | #1 |
Newbie Join Date: Aug 2008 Location: somewhere
| how to wire
series and paralell, i thought one was +&+ and -&- at the plug, and one was a + from one pack and a - from the other pack and the other +&- together? if that makes any sence.
08-23-2008, 09:54 PM | #2 |
Rock Crawler Join Date: Jul 2008 Location: E. City
are you talking motors or batteries?
08-23-2008, 09:55 PM | #3 |
RCC Addict Join Date: Jun 2008 Location: Fresno
08-23-2008, 10:01 PM | #4 |
RCC Addict Join Date: Jun 2008 Location: Mudville
if you take 2 cells and wire the pluses together and the negs together, then put a end on it, that is in parralle. if you wire the plus to the minus on one end of the 2 cells, and then the connector ends to the plus and the minus, that is in series. wireing in a parralled keeps the voltage constant. ie 4 cells in series gives 1.2v, which is what 1 cell provides. wireing in series adds the voltage of each cell. so 4 cells in parrallel willl give 4.8v. you can also wire packs in series, then wire the packs together in parralled. ie 8 cells, two packs of 4. each pack is wired in series, providing 4.8v then the packs are wired together in parrallel, Plus to plus, minus to minus, you still get 4.8v, but have double the runtime. now im not sure how wireing in series or parrallel effects amps, but it does. i think the info above is correct, im not an expert in batterys or wireing by any means, but that should give you a basic understanding of it anyways. Last edited by Timmahh; 08-24-2008 at 01:39 AM. Reason: to tired to type |
08-23-2008, 11:41 PM | #5 |
Quarry Creeper Join Date: Apr 2007 Location: St. Louis
Plus to Plus and Negitive to Negitive = Parallel, voltage is the same but capacity adds. Plus to Negitive and so forth = Series, voltage adds but capacity remains the same. |
08-24-2008, 03:00 AM | #6 |
Pebble Pounder Join Date: Jul 2008 Location: Toronto
check this out, it shows diagrams on wiring based on your input... http://www.scriptasylum.com/rc_speed/_wiring.html cheers |
