08-26-2008, 08:50 PM | #1 |
Newbie Join Date: Aug 2008 Location: California, the 530
| Custom Chassis Suspension problem
I have a problem with the suspention on my custom chassis. Wehn it climbs up tall things, the shocks extend all the way and the suspention links are almost vertical. I need YOUR IDEAS BADLY!!! |
08-26-2008, 08:52 PM | #2 |
Quarry Creeper Join Date: Jan 2006 Location: Atlanta GA
shorter shocks, limit the shocks.
08-26-2008, 09:04 PM | #3 |
i think it would be easier to make the shock tower higher
08-26-2008, 09:48 PM | #4 |
Quarry Creeper Join Date: Jul 2008 Location: Minot
Limiter straps.
08-26-2008, 11:24 PM | #5 |
Rock Crawler Join Date: Nov 2007 Location: San Bernardino
| Doing this will not solve your issue... with this much travel you will have axle stear... very bad!!!!! you need to add a limiter to the shock such as fuel tubing inside below the piston. Or use a smaller/ shorter shock. Good luck let us know what you came up with....
08-27-2008, 12:38 AM | #6 |
Quarry Creeper Join Date: Jul 2006 Location: Salem
You could also use longer links
08-27-2008, 06:37 PM | #7 |
i will tie a strap to the axle and i cut a staw and put it inside the shock to limit the travel Thanks Much!! |
08-27-2008, 09:17 PM | #8 |
Quarry Creeper Join Date: Apr 2006 Location: Gervais
08-27-2008, 09:19 PM | #9 |
Looks fine to me, run it!
08-27-2008, 09:43 PM | #10 |
I wanna be Dave Join Date: Apr 2005 Location: Vegas
08-27-2008, 10:07 PM | #11 |
Who's your Daddy-0! Join Date: Mar 2008 Location: Augusta
x3! Go with it man. It will go where no scaler has gone before! And if your going to use the straws, use TGI Fridays straws, there are much stronger!
08-27-2008, 10:56 PM | #12 |
09-06-2008, 09:02 PM | #13 |
now i am going to be running four-link in the front and leafs in the back
09-07-2008, 02:14 AM | #14 |
Rock Stacker Join Date: Apr 2008 Location: auburn
move the top shock mounts forward or angle the shocks to the center of the frame
09-07-2008, 07:34 PM | #15 |
Pebble Pounder Join Date: Mar 2006 Location: Placerville
Does anyone know where to get a quarter-elliptical spring pack? If they are available one could use them as part of a modified 4-link design (as upper or lower links with a rigid mount at both ends) or in a 6-link configuration (with a flexible mount at the axle end, possibly parallel to lower links) the possibilities far exceed what I have written here... Designed properly such a system could be self limiting in travel (but not overly so) and help resist the dreaded body roll/torque twist problem...
