08-31-2008, 05:07 AM | #1 |
| Tranny Lube Question
I just bought a new AX-10 Transmission for a project. The instructions were not like the instructions in my AX-10 kit. Everything was the same except it did not show that I should gease the tranny gears, where the truck kit instrucions show that you do. I can't remember what my gears were in the truck kit, but with this tranny, there is a combination of metal and plastic grears, with no metal to metal contact. The only reason I can think of for the difference is that if the truck kit had all metal gears in the tranny. (but I can't remember). Can anyone shed some light on this? Does this tranny with the plastic/metal combo need grease? I'm thinkng not since it isn't much different that a plastic spur meshed with a metal pinion. I would just like to be sure. Thanks. |
08-31-2008, 11:12 AM | #2 |
Pebble Pounder Join Date: Apr 2008 Location: Concord
The kit should have only come with the plastic/metal gear combo. I use lithium on my gears and it works fine. You could probably run it dry without a problem.
08-31-2008, 11:33 AM | #3 |
RCC Addict Join Date: Feb 2006 Location: ccxc
I just rebuilt mine and used Stealth lube from Associated.........seems to work good
08-31-2008, 11:50 AM | #4 |
Moderator Join Date: Jul 2007 Location: Texas baby!
I run my tranny dry. I don't think there is any need for lube.
08-31-2008, 02:04 PM | #5 |
RCC Addict Join Date: Jun 2008 Location: Fresno
the way i see it... "when in doubt use lube" personally i use rocksmith's gear jelly for every thing. this stuff is amazing! |
08-31-2008, 04:41 PM | #6 |
Quarry Creeper Join Date: May 2008 Location: Hartsville, SC
I use KY JELLY.lol
