i keep brakeing my ax 10 artr drive shaft how do i fix hey all i hav an ax 10 artr and my drive shaft keeps coming off any ideas??? help |
try a little thread locker on the set screw and let it dry or upgrade to mip drive shafts |
where is it comeing off from. the trans output or is the yoke popping of the pins |
poping off the pins |
zip tie |
some companys are making retainers that slide over the yokes to prevent them from bending and popping off, you may wanna check on those. save you from haveing to spend a lot of $ if your strapped for cash. If you got plenty of money buy the MIP's. One set for you and One set for me. |
heres some ratainers. http://www.tcscrawlers.com/search.ph...=search&page=1 |
thanks got a link for the mips |
http://www.tcscrawlers.com/MIP-C-Dri...1-p-16872.html |
kool |
any more sugestions? |
A much cheaper option are the Traxxas long half shafts. They hold up 100% better than the Axials. I have yet to pop one off the yoke. http://www3.towerhobbies.com/cgi-bin...&I=LXJJ82&P=ML |
I have a set of the 'Pede shafts, and I am unsure if I should install them or get the collars for the stock shafts...:?: |
Go with Pede shafts, they work alot better. |
The RC4wd Punisher Shafts are expensive......BUT SO WORTH IT. |
do you need to put the metal parts in in order to switch to the stampede shafts? or just the actual plastic shafts themselves and you're good? |
