09-02-2008, 01:44 PM | #1 |
Newbie Join Date: Nov 2005 Location: HARRISONBURG
| R2D trans question
Just bought an r2d trans and am wondering how you keep the fluid in the trans out of the motor when there is no kind of seal between the trans and motor.searched for this but had no luck.please help!
09-02-2008, 02:41 PM | #2 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
09-02-2008, 02:50 PM | #3 |
RCC Addict Join Date: Jan 2008 Location: Mount Juliet
I am betting that he is referencing the RC4WD Lube.
09-02-2008, 03:28 PM | #4 |
The best thing I've found to lube the R2D including RC4WD lube is "GearJelly" by Rocksmith Engineering. I've found it sticks to the gear faces longer than any other lube. It also quiets down the gears as the R2 is a noisy little sucker. You can find Rocksmith on the vendor site here on RCC. I'm not aware of anyone using a liquid crankcase type lubricant inside the R2D transmission.
09-02-2008, 03:34 PM | #5 |
support@rc4wd.com Join Date: Nov 2007 Location: Lancaster, Ohio
Yea its a lube not an oil. Nothing stopped the water from getting in my motor either |
09-02-2008, 03:38 PM | #6 |
RCC Addict Join Date: Jun 2008 Location: Mudville
why not wheel bearing grease? i have some good high temp stuff i here on all my bearings and gears in my bajas, and planned on useing it in my crawler project with the vf dig? any reason why i shouldnt use it. seems to me it would be perfect, high stick, doesnt melt away at higher temps so no running or mess leaking out. and it lasts forever, or should in these units, plus should provide very good lubrication. |
