09-11-2008, 04:05 PM | #1 |
Quarry Creeper Join Date: Jun 2007 Location: Tucson
| How ghetto would this be?
Ok I need to extended patch cable to reach from my MM to my lipo and motor, I just don't have the same type of wire to use, how ever I do have the same gauge speaker wire that I can make my run with the deans conectors. I am going to move my MM my rear axle of my SW3 just to help with the cog. I have my rig in the TLT section. |
09-11-2008, 04:41 PM | #2 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
Speaker wire is different from the type of wire used in RC's. You'll probably burn something up.
09-11-2008, 04:48 PM | #3 |
I thought all wire is the same depending on how many strands the more strands the more flexable it is at a given gauge? Or am I missing something? |
09-11-2008, 06:34 PM | #4 |
Quarry Creeper Join Date: Nov 2007 Location: NH
dragon, you are correct, the more strands the more flexible. The difference would be is the gauge (or diameter) of the wire. But by saying speaker wire doesn't really clarify what your trying to ask. I've seen speaker wire from 22 ga (very small) to 10 ga (monster cable). so depending on what size wire you using for which application, I don't think you would want the use 22ga speaker wire to extend your motor leads, and it doesn't make much sense to use 10 ga to extend you signal wires. As long as you use at least the same size wire as the manufacturer for which ever application, yes it will be "ghetto" but it will work.
09-11-2008, 06:48 PM | #5 | |
Pebble Pounder Join Date: Dec 2005 Location: Metro NYC
Some of the high end BL motors are supplied w a teflon jacket. | |
09-11-2008, 07:15 PM | #6 | |
RCC Addict Join Date: Jan 2004 Location: Gunbarrel
The reason for silicone insulation in R/C world would be for flexibility and cost. Last edited by Rogue; 09-11-2008 at 07:18 PM. | |
09-11-2008, 07:29 PM | #7 |
Ok that is what I thought I was planning on using the same gauge wire, it's just for now kinda out of a job right now, I have a interview on Monday I passed the 2 phone interviews!
09-13-2008, 01:35 AM | #8 |
Quarry Creeper Join Date: Jul 2005 Location: pleasant ridge
speaker type wire will work the only problem is the larger strands in the speaker wire will flex till they break faster than the rc type wire.thats why houses use single strand wire and cars use multi strand.houses dont move so no flex cars move so multi strand.the more movement the more strands to reduce breakage.my ghetto ass make it work mentality has used leftover single strand house wire for my speed control on my beater.worked fine for longer than i thought it would.
09-13-2008, 01:36 AM | #9 |
09-13-2008, 05:54 PM | #10 |
Thanks,...Thatguy
09-13-2008, 11:01 PM | #11 | |
Quarry Creeper Join Date: Jul 2008 Location: Erin, Ontario, CANADA
Some heat is generated due to the high current involved and the small amount of resistance that exisits in your battery & ESC wires (P=I squared R). I'd be concerned about the wire getting hot enough to melt the type of insulation as used on speaker wire. If that happens and your conductors short, then you have a real problem. Narly1 | |
09-13-2008, 11:47 PM | #12 |
Rock Stacker Join Date: Feb 2008 Location: Mason City
Get Deans Wet Noodle...Make the wire length sort as possible!! The longer the wire, the more Resisance, which creates heat. I have had success with stiff appliance copper wire that you can get at Menards Lowes Home Depot, Mills Fleet Farm. On the batteries I would use only the best, WET NOODLE!!
09-14-2008, 01:06 AM | #13 | |
Not trying to pick on you but P=I squared R is ohms law for calculation of power and not resistance. | |
10-08-2008, 02:39 PM | #14 | |
From a theoretical sense you are correct that insulation does not have any effect on the current carrying capacity of the conductor. HOWEVER, from a practical sense you want an insulation that can take a little heat. It's not the low resistance of the conductor that causes the problem, it's the amount of power it dissipates. And while you are correct that the amount of current is usually not high enough to worry about, when you add the cumulative heating effects of current over time + a stalled motor + high ambient operating temperature + a potentially undersized conductor, that's enough to scare me away from using vinyl jacketed speaker wirein this application. One of the key specs when choosing insulated wire is it's maximum temperature rating. And I believe I was using the correct formula for power, which is what I was referring to at the start of the sentence containing the formula P=I squared R. Heat in a conductor is a product of the power it has to dissipate. Narly1 | |
10-08-2008, 07:27 PM | #15 |
Rock Crawler Join Date: Jun 2008 Location: Clinton,Michigan
just forget everything posted above and go wireless. lol It will work I promise. |
10-08-2008, 07:50 PM | #16 |
I wanna be Dave Join Date: Aug 2008 Location: cape crud... will you be my friend
10-10-2008, 09:02 PM | #17 |
