Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: how much should a 2.2 class crawler weigh??
Old 09-22-2008, 07:56 PM   #1
Default how much should a 2.2 class crawler weigh??
What is a good base line for the total weight of the car??
And how should the weight be balanced???
I am just looking for some information, we have 6 different 2,2 class RC crawlers where i work (Trail Gear):-P and lately I have been stealing them and throwing them on the scale, now that I have all the weights, i want to look for corelations between the weight and how it is split up and the performance of the car.
Tattoo John is offline   Reply With Quote
Old 09-22-2008, 08:12 PM   #2
LIKES2CRAWL's Avatar
Alot of it is personal prefrence, and depending on how much traction your terain you play on has. If the rocks you run on have alot of traction you can get away with a lighter rig, etc. My 2.2 weighs about 6lbs 8oz. and it's about 60/40 weight ballanced (front heavy) so if the front end gets over a peak it will help pull down to keep from getting high centered, better to go forward then get reverse points.
LIKES2CRAWL is offline   Reply With Quote
Old 09-22-2008, 08:18 PM   #3
well its all gonna depend on how its setup and if its a tvp or tube chassis. In general though 2.2 comp rigs weigh between 5.5 and 7 pounds. As far as weigh distribution you wan tht e weigh more up front. I would say 60-70% up front and 40-30% out back. Oh and you want the weight as low as you can get it. Keep the electronics and batteries low and weight in the wheels.
bigflex is offline   Reply With Quote
Old 09-22-2008, 08:20 PM   #4
Agreed, my rig weighs 6 lbs even and at least 60% is in the front
coolkidjf7 is offline   Reply With Quote
Old 09-22-2008, 08:28 PM   #5
2x
mtnyote is offline   Reply With Quote
Old 09-22-2008, 09:49 PM   #6
2D
Harvo's Avatar
5 lbs with the new rebuild and its front heavy. I like balance though, so I didn't over do it with the front bias. My crawler can carry a front or rear wheel over a gap and I can back up just about anything I can crawl up forward.
Harvo is offline   Reply With Quote
Old 09-22-2008, 10:29 PM   #7
Tech Addict
frdtrkguy's Avatar
I just built a new rig that weighs 5lbs a full pound less than my previous set up and let me tell you that it made a huge improvement. I also biased the weight as far forward a possible. The new truck will make lines that my old one couldnt.
frdtrkguy is online now   Reply With Quote
Old 09-23-2008, 06:42 AM   #8
my axial is 4 lbs.-10 oz., 6 oz. in each front wheel and 4 in each rear. Very happy with its performance. I've got to be careful on the large tumbles. Not to mention, the lighter the rig, the more ground clearance you can have without sacraficing COG
sierradmax is offline   Reply With Quote
Old 09-23-2008, 06:49 AM   #9
mine axial is about 6-7 pounds, but i have aluminum axle casings to help the low CG.
smm_cbf is offline   Reply With Quote
Old 09-23-2008, 08:59 AM   #10
My comp rig weighs 5.25lb and my sons is right at 5.50lb. We like to run all of our electronics centralized and low and use lighter/heavier tire pairs to adjust front/rear weight balance as needed depending on the course.
John82601 is online now   Reply With Quote
Old 09-23-2008, 03:37 PM   #11
Man I Feel Fat Mine Is Almost 8 Pounds
Texas_TJ is offline   Reply With Quote
Old 09-23-2008, 07:01 PM   #12
Default 2.2 weight
well mine is really fat it scales at 8.5 lbs with a 55/45 split...
i have 16oz weight in each tire and the batt on the servo,for my batt i run a 6cell Nicad cube
southernextreme is offline   Reply With Quote
Old 09-23-2008, 07:05 PM   #13
Have you guys weighed front and back to see what your balance really is?
LoveToROCK is offline   Reply With Quote
Old 09-23-2008, 07:53 PM   #14
Gold Star Baby!
Stormin2u's Avatar
Location: Taylors Falls just hanging with the MNRCRC crew.
I think LIKES2CRAWL nailed it.
Stormin2u is offline   Reply With Quote
Old 09-24-2008, 09:55 AM   #15
[quote=Stormin2u;1355238]I think LIKES2CRAWL nailed it.[/quote
did do same for me
bodybags101 is offline   Reply With Quote
