Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: more proof I'm dumb
Old 09-28-2008, 07:03 PM   #1
Default more proof I'm dumb
What is the four AA battery pack
that came with my
controller and servo for? It isn't
mentioned in instructions yet has
a plug connection for the esc and an
on/off switch inline.
I didn't install it and all works fine
but I'm fearfull I'm
gonna fry something by not
using it somehow.
TIA... I remain a dumb newbie.
Gundy is offline   Reply With Quote
Old 09-28-2008, 07:08 PM   #2
i think that battery pack(4aa cell thing) is if you run a nitro vehicle.... Iam 99% sure thats what its for.
barbaricboye is offline   Reply With Quote
Old 09-28-2008, 07:11 PM   #3
that would be a reciever pack... you WONT need it if your esc has 3 wires going to it...the reciever will get power through your ESC..
or, if you want to use a RX pack.. you need to clip, and tape off, the power wires between your RX and ESC, and just leave the signal wire.
theres not much of a gain in runtimes, except for the added weight of another pack.
PEDEcrawlerguy is online now   Reply With Quote
Old 09-28-2008, 07:22 PM   #4
Default thanks
I feel relieved!
I'm learning as fast
as I can but I'm
impatient.
Thanks guys.
This new hobby is
becoming an addiction. :-)
Old 09-28-2008, 08:34 PM   #5
mjh
Originally Posted by Gundy View Post
I feel relieved!
as I can but I'm
impatient.
Thanks guys.
This new hobby is
No such thing as a dumb Q:
If you don't know you don't know
Better then letting the magic smoke go!
Cheers....MJH
mjh is offline   Reply With Quote
Old 09-28-2008, 09:13 PM   #6
Mayor of Bedrock
freetimecrawler's Avatar
that came with my
using it somehow.
A few points I differ on slightly here.
1. Saying you "WON'T need it, if your ESC has Three wires going to it. The reciever will get power through your ESC"
That statement may be only partially correct, many ESC's don't have high enough BEC to fully power the high torque servo's most serious crawlers use. You'll find many people using external BEC's to power servos.
You'll want at lease 5.0 amps BEC if you want to send decent power to the servo's. Better yet, get a CC BEC and you won't have a problem, or need the extra reciever pack, or weight of it.
2. I find it better to just take a small screwdriver, and push the (usually middle) Red wire out of the ESC with it's pin intact, and put some shrink tube around it so it doesn't short out. By leaving the pin intact, you can always remove the shrink tube, and push the pin back in if you decide to use that ESC for something else. Also, better if you should ever need to return the ESC for factory service.
3. Not a lot of gained run time is fairly accurate, but......with a reciever, or even better a CC external BEC, you will notice a gain in servo power
freetimecrawler is offline   Reply With Quote
