Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: what foam?
Old 09-29-2008, 05:59 PM   #1
Rockaholic
ebomb's Avatar
Default what foam?
what foam do i use with losi rock claws?the foam that comes with it and star cut them or get some memory foam. sorry if question has been ask, did search so much info but not what i wanted and where can i find how to cut stars for my foams
ebomb is offline   Reply With Quote
Old 09-29-2008, 06:05 PM   #2
CBR
I always had good performance from the memory foams, that RPP sells. If you really want your Losi's to perform... throw them to the dog and get the Panthers!
CBR is online now   Reply With Quote
Old 09-29-2008, 06:10 PM   #3
I still think Losi's are the best tire out there in all areas. Panthers are a good tire but not for off camber stuff. I would run either memory or cut down standard foams in the front and just leave the rear standards as is so that they don't squat on climbs.
rc4x4crawler is offline   Reply With Quote
Old 09-29-2008, 06:18 PM   #4
Nothhwest traction technology, Stock Axial's or Stock Losi's are all great choices. NTT foams can be bought at The crawler store.
JUSTGOINGSLOW is offline   Reply With Quote
Old 09-29-2008, 06:21 PM   #5
I have had good luck with the losi claws running Memory/standard hybrids in front,( memory in inner and middle of tire, and a slice of standard on the side wall side to keep it from folding over on sidehills) and cut down standards in rear to control squat alittle.
BR4x4 is offline   Reply With Quote
Old 09-30-2008, 06:03 AM   #6
hardhead's Avatar
8# Rockhammer Squat - 4.75" dia. x 2.625" wide up front 5# Rockhammer Hybrid Reach - 5.25" dia. x 2.25" wide in the rear; works outstanding
hardhead is offline   Reply With Quote
