| | #1 |
| 2D ![]() Join Date: Mar 2008 Location: Dodging Bullets
| I guess this is rhetoric... but I have been experimenting with some different tires and foam setups lately. I have seen several times when my Panthers have so much traction in cracks or when they get bound up that the tires just wad up... sometimes so much that it stalls out my setup. When running the claws, they seem to have almost as much traction (depending on the surface) but don't get bound or wad up as much as the Panthers. They continue to spin and eventually climb out of the bind. This usually results in a more controlled exit of the spot. There are situations where the Panther's traction just can't be beat... and it's a great thing. But when there is so much traction that it stalls you out (or breaks you... depending on voltage |
| Sponsored Links | |
| | #2 |
| TEAM MODERATOR ![]() Join Date: Jul 2004 Location: Chit Chat
| More foam stiffness in the Panther. |
| | #3 |
| '08 2.2 National Champ ![]() Join Date: Nov 2006 Location: UTRCRC
| Yep, a stiffer foam will fix that problem. You will still have insane traction too. |
| | #4 |
| I have two memory foams stuffed in each Panther. I was running with no vent holes and found traction to be fine, but I was deflecting in places where I thought they should just climb. So I vented them and got better traction and less deflection, but that is when the wadding problem started. |
| | #5 |
| Memory foam is over-rated. |
| | #6 |
| ... Join Date: Sep 2005 Location: USA
| | #7 |
| | #8 |
| Scale'n ![]() Join Date: Sep 2005 Location: *
| | #9 |
| RCC Addict Join Date: Jan 2008 Location: Uhh Dunno....
| | #10 |
| | #11 |
| | #12 |
| Day By Day ![]() Join Date: Nov 2006 Location: spring hill TN
| I have also decided that memory foam is way over rated. I have been working with the panther white stiff foam.You have to take and push the foam from the side and trim the buldge out of the center to keep it from ballooning the center of the tread out and that is it. |
| | #13 |
| | #14 |
| Gavyn is my BFFL ![]() Join Date: Feb 2007 Location: hunting pandas
| | #15 |
| Newbie Join Date: Sep 2007 Location: CO
| | #16 |
| Pebble Pounder Join Date: Aug 2008 Location: San Diego
| I would never think you could have to much traction. I thought traction was a good thing. |
| | #17 | |
The lizard foams are helping, Will make due with that for now. Thanks. | |
| | #18 |
| | #19 |
| When it wads up in a cack instead of moving forward, the traction is doing you no good. What I am eferring to is a little worse than in the pic above. That pic just looks like you need stiffer foam. |
| | #20 |
| Thread Tools | |
| Display Modes | |
