shock oil Hey guys i have a Cr01 and the shocks are starting to leak , what weight shock oil should i use , ive never changed shock oil b4. And a brand of what one i should use would be nice |
Changing the oil wont fix the leak. You need to find out why they are leaking first, fix that and then add the weight oil that you need. |
well i need more oil i think becasue one of the shocks seems really low , i was accutally thinking aabout just changing the shocks all togeather , do you know ifs its hard to do or what a good replacement fo the stock ones would be ? |
Well, I dont have one of those trucks, but I am sure that there are plenty of shocks that will fit. All you need to do is find a set that are the same lengths as what you have now. |
They sell shock rebuild kits. You most likely can fix it if you know what the shocks are from. |
