TXT axle ? i want to get a set of stock txt axles i have 2.2 rim and tires what do i need to make the rims and tires fit? i never worked on a txt so i dont know thanks for your help |
the TXT uses a spline drive instead of a cross pin, if you get a complete set it will have a 12mm brass splined hex. then all you have to check is the backspacing of the wheel. not enough and it will rub the axle C |
