10-11-2008, 01:11 PM | #1 |
Pebble Pounder Join Date: May 2007 Location: socal
| lower cg
how to lower the cg and lower the ride hight??????????
10-11-2008, 01:15 PM | #2 |
Newbie Join Date: Oct 2008 Location: Williamstown
| From looking through these forums, it seems like everyone is putting the battery on the front upper link. Makes sense because it puts the battery much lower. If the battery is moved to the upper link, does the plug still reach the plug for the ESC in it's stock location?? |
10-11-2008, 01:18 PM | #3 |
Newbie Join Date: Sep 2008 Location: dallas
Lower the height by moving your shocks to the chassis not the plastic top plate
10-11-2008, 02:00 PM | #4 | |
Quarry Creeper Join Date: Jul 2008 Location: Lawton
10-13-2008, 10:23 PM | #5 |
Newbie Join Date: Jan 2008 Location: twin falls
droop. and mount electronics as low as possible.
10-13-2008, 11:08 PM | #6 |
Quarry Creeper Join Date: Jul 2008 Location: Galt
Lower CG: • wheel weights • move battery to front axle • move ESC to front upper links • move receiver to rear upper links Lower ride height: • use a droop suspension OR • replace shocks with shorter ones OR • disassemble shocks, insert a nylon spacer or plastic tube around the shock shaft INSIDE the shock, reassemble shocks. |
