10-19-2008, 06:45 PM | #1 |
Pebble Pounder Join Date: Aug 2007 Location: Greenwood
| 55t stalling
i just got a novak 55t and it is stalling aloti am runing 6 cell 1500 2/3 cells do i need more voltage or what
10-19-2008, 08:39 PM | #2 |
Newbie Join Date: Oct 2008 Location: gilroy
| what tooth pinion and spur? try a 11T pinnion if u stick with a 6 cell. get a capasiter for the the novac ESC $10.00 but 1st try a recevier pack 6.v nimh for the receiver. or aka 5 cell 2/3 nimh is it the motor studdering or is the whole rig glitching..? |
10-19-2008, 09:51 PM | #3 |
I wanna be Dave Join Date: Jun 2005 Location: drillin Holes for the man
ok what gearing are you running. if you are running the 87-14 to keep it from stalluing your gonna need to volt up. Or you can drop down to a 12t pinion or stay with the 14 and step up to a 90t spur. Either will solve the stalling problem. |
10-19-2008, 09:53 PM | #4 |
| He said it is stalling. In other words when he gets it in a bind it stalls out. They don't make 11t 48p pinions, and a reciever pack won't help. Neither will a cap. Those would only help with glitching. Totally different than what he is saying. Oh and on a crawler its better to add and external BEC rather than another battery pack. |
10-19-2008, 10:23 PM | #5 | |
Gear down and volt up...one or both,that will help or get rid of stalling. A good motor will do better as well. | |
10-20-2008, 03:57 PM | #6 |
Rock Stacker Join Date: Jan 2005 Location: SE, Aust.
I am also currently running the same motor on stock gearing with 2 cell lipo... I did not find it to stall all that often the only time i can stall it out is in a pretty bad bind.... |
10-20-2008, 06:38 PM | #7 |
Rock Stacker Join Date: Sep 2008 Location: ontario, canada
maybe a brush is hanging up???? if the other ideas do not work for you
10-20-2008, 11:37 PM | #8 |
Newbie Join Date: Mar 2008 Location: Marshall
Just remember, when you "volt-up & gear down" you will at some point find the limits of your driveshafts, lockers, outputs, etc. Also, you need to stay within the voltage limits of your esc. I don't mean to be a killjoy, you just need to keep these things in mind. |
10-21-2008, 05:59 PM | #9 |
Quarry Creeper Join Date: Apr 2007 Location: St. Louis
How old are your brushes, do you have good spring tension on your brushes?
10-21-2008, 09:18 PM | #10 |
10-21-2008, 09:54 PM | #11 |
Is your pinion meshed too tightly against your spur gear? Does your truck have a loud whine when it runs? Sometimes people just pop in a new motor and tighten it down, not considering how much resistance a tight mesh creates. Ask me how I know |
