10-24-2008, 05:29 PM | #1 |
Newbie Join Date: Jul 2008 Location: philippines
| advantage of having a droop set-up
hi! i'm getting my ARTR very soon. i have a question regarding DROOP SET-UP. what are the advantages and disadvantages? i'm trying to search for it but i can't find the search button. TIA! |
10-24-2008, 05:36 PM | #2 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
Search has been turned off probably.... server issues. Anyway, droop will give you a much lower ride hieght. But if you are happy with a sprung setup, droop might not be for you. |
10-24-2008, 08:06 PM | #3 |
Pebble Pounder Join Date: Mar 2008 Location: yes
I am personally not happy with my sprung setup. I have a stock axial with maxx size shocks, all the electronics mounted below the tops of the tires, and 10 oz. of lead in front tires/2 oz. lead in back. This all sounds great until you realize that the cg is still too high. It won't even stand sideways on the rims like my old tlt BMVii with twice the ground clearance. I just want to know if droop will help the cg because ground clearance is not much of an issue.
10-27-2008, 10:07 PM | #4 |
RCC Addict Join Date: Nov 2007 Location: in the woods
I know people are probably getting sick of me saying this but try a 50/50 setup. I love mine |
10-28-2008, 06:22 PM | #5 |
Newbie Join Date: Oct 2008 Location: Fullerton
By having a full droop set up or a 50 / 50 set up, how is that on the torque twist? I have a MRC and with no preloads (so with droop) the torque twist was not good. So preloads went back in.
10-28-2008, 06:26 PM | #6 |
Rock Crawler Join Date: Apr 2008 Location: Rancho Cucamonga
If you run a droop set up it will lower your ride height quite a bit but this can be good on a lot of terrain. Also having a droop set up will help get rid of torque twist if set up correctly.( shock oil, internal spring tension etc.)
10-28-2008, 08:15 PM | #7 |
RCC Addict Join Date: Sep 2007 Location: Westland, MI
There are alot of advantages to a droop setup but there are alot of disadvantages. A droop setup will lower your CoG but it will also decrease your ground clearance. the main thing you want to try is to keep your weight between the center line of the axles and the top of the tires. It will improve most aspects of your rig. I would recomend a droop set up that gives you clearance. I run a reverse sprung setup that rides high I have 2 3/8" ground clearance. You need to experiment and learn what works best for you. |
10-28-2008, 10:22 PM | #8 |
Quarry Creeper Join Date: Nov 2007 Location: southender
i sugest trying both and finding what works for you like hitman said it's all about prefrence.
11-05-2008, 10:31 AM | #9 |
RCC Addict Join Date: Oct 2008 Location: Finland
How thick oil is generally used in droop setups? Are there any alternatives to rc shock oils?
11-05-2008, 06:51 PM | #10 |
Rock Stacker Join Date: May 2008 Location: united states
I run Droop on my rig and I like it very well. It is true that you will losse clearance running a droop...BUT only if you do not use a chassis setup for droop. The chassis I am running ATM is made just fro droop, I have over 3" of ground clearance pushing 4" and I love it. I am running berg axles as well. On the same chassis running BIGBORES in a droop with my ax10 I had about 2-5/8" ground clearance, that was about as high as I could go without messing up the balance of the rig. as far as shock oil goes, I have tried 25w,45w and I am using 80w atm. I like the control of 80w its smooth for my wieght but not tooo slow. |
11-05-2008, 07:00 PM | #11 |
Quarry Creeper Join Date: Jul 2007 Location: 517
Droop setup is a fail on the stock ax-10 chassis. I run springs under, no oil in the front (it keeps leaking out), rear has springs under and 100 wt. Small tip, if you run droop, flip the shocks upside down, keeps more weight down low |
11-05-2008, 07:14 PM | #12 |
Pebble Pounder Join Date: Jan 2005 Location: socal
i run full droop with big bores with 60wt oil on a top bannana chassis. i have 2 1/4in at rest and just under 4 at full droop.
11-05-2008, 09:13 PM | #13 |
Newbie Join Date: Oct 2008 Location: Springfield
11-05-2008, 10:39 PM | #14 |
11-05-2008, 10:55 PM | #15 |
I wanna be Dave Join Date: Sep 2005 Location: *
11-06-2008, 03:55 PM | #16 |
Here are some pictures.... |
11-07-2008, 12:54 AM | #17 |
Thanks for the pics, that clears it up nicely.
11-08-2008, 04:56 PM | #18 |
RCC Addict Join Date: Nov 2008 Location: never been
11-17-2008, 11:55 AM | #19 | |
Newbie Join Date: Jul 2008 Location: Rosedale/Bakersfield
I will be flipping my shocks as well. I'm using these shocks: http://www.ckrccrawlers.com/shop/ind...roducts_id=766 I'm also ditching the Krawler tires (what we call them in the 1:1 world) and I ordered some Losi Claws, and put in an order for the Mayhem Eng. comp phatty's with the bearing weights. I'm trying to convert to a comp rig, but without swapping everything out to another chassis. Here are a few pics of my rig now, with springs. Last edited by Grind; 11-17-2008 at 11:58 AM. | |
11-19-2008, 11:29 AM | #20 |
Newbie Join Date: Jul 2007 Location: Adrian
