11-12-2008, 03:48 PM | #41 |
Newbie Join Date: Oct 2008 Location: chisago city
no i mean wat one of those do u think i should make
11-12-2008, 03:51 PM | #42 |
I wanna be Dave Join Date: Aug 2008 Location: cape crud... will you be my friend
i was thinking of making an xtrail with axial parts.... but thats just me. actually i am going to be making a cr01. |
11-12-2008, 04:40 PM | #43 |
Rock Crawler Join Date: Nov 2007 Location: San Bernardino
Nitrosport.......Hope this helps. the xtrail is a great scale chassis that si maily design to be a direct bolt on for the AX-10.It provides and easy and in expensive way for YOU to create a scale based rig for under aprox $300 (if you buy the xtrail, and ax-10 rtr) That is a very good price for ANY rtr scaler. Can you build up the xtrail with a wheely king? YES!! It would just require alot of fabrication of some custome parts and may not be woth YOUR time based upon my impression of what I have read so far. If you want a quick, easy inexpensive way to build a scaler... buy the ax-10 rtr and the xtrail......and go play!!! |
11-12-2008, 05:04 PM | #44 |
pretty much the same thing i have been saying all along. thanks |
11-13-2008, 12:01 AM | #45 |
| I know LOL |
11-13-2008, 02:06 PM | #46 |
dont worry my dad has alot of tools
11-15-2008, 05:39 AM | #47 |
Quarry Creeper Join Date: Nov 2006 Location: Rats nest Grafton ND
The AX 10 Ready to Run (RTR) has better gear to start with then the Wheely King. The setup of the AX10 out of the box is much better then the WK. The WK axles are to wide for the most part which makes them not very good for most scale type builds. You can use alot more of the Axial parts in a build then you can the Wheely king. So all in all it is actually going to cost you more to build one with a WheelyKing then it would if you did it with an AX10. |
