11-04-2008, 02:27 AM | #1 |
Rock Stacker Join Date: Apr 2008 Location: Vienna
| question about motor-connection to esc
hi I am not much of an electrician, and have the following question: does connecting the motor to the esc with such a device has any negativ impact (electronically)? device: sincerly |
11-04-2008, 04:35 AM | #2 |
Who's your Daddy-0! Join Date: Mar 2008 Location: Augusta
What kind of plug is that Why does it have 4 prongs? I would suggest using a "Deans" plug or just soldier the + and - straight to the motor from the ESC. What are you using it on RC wise?
11-04-2008, 04:50 AM | #3 |
hi this plug has 4 skrews to fixate the 4 cable-ends. it's innards are of brass, i think. normaly we use this kind of plug to connect lamps to the power-lines. in german it is called "lusterklemme". but i don't know about it's impact in performance when connecting an esc to a motor with it. sincerly |
11-04-2008, 04:52 AM | #4 |
Rock Crawler Join Date: Jan 2007 Location: Secret Crawl Location Deep In England
I think they are called a 'chocolate block'. You wont lose any power that you would notice in a crawler, maybe in a mod tourer. As above go with deans. matt |
11-04-2008, 04:53 AM | #5 |
hi thanks for the quick response sincerly |
11-04-2008, 06:24 AM | #6 |
Pebble Pounder Join Date: Apr 2008 Location: Aurora
Location: Aurora Posts: 8 Join Date: Apr 2008 If you are looking to be able to disconnect your motor from your esc i would go with bullit connectors. Castle Creations make some nice ones also you can get them from eflite as well, any well stocked rc shop should have some to choose from. Just know what size wire you are using, they come in different sizes. |
11-04-2008, 09:09 AM | #7 |
Quarry Creeper Join Date: Apr 2007 Location: St. Louis
What you have there is a European terminal block/strip. For crawlers it is ok to use. I would tin the wire ends before inserting and tightening down the screws.
11-05-2008, 12:28 AM | #8 |
hi i did tin the wires before fixing them. thank you all for your responses sincerly |
11-04-2009, 05:57 AM | #9 |
Newbie Join Date: Aug 2007 Location: Linz, Austria
| Aderendhülse
even it's an old thread, but it's important. NEVER tin wires when fixing with screws. The tin will get lose an the connection will heat up. You have to use core end sleeves in germen: NIE Kabelenden verzinnen, wenn sie geklemmt werden. Das Lötzinn gibt mit der Zeit nach und die Verbindung wird locker. Dadurch erhitzt sich die Verbindung (es brutzelt) Um Lizendrähte zu klemmen muß eine Adernendhülse verwendet werden. http://de.wikipedia.org/wiki/Aderendh%C3%BClse |
