05-23-2012, 01:16 AM | #41 |
| re: RC Crawler Glossary of Terms
IIRC = If I recall correctly. (One of the more common ETLAs generally used online.) Oh, and... ETLA = Extended TLA TLA = Three Letter Acronym |
05-23-2012, 05:07 AM | #42 |
Rock Crawler Join Date: Mar 2011 Location: hampton
| re: RC Crawler Glossary of Terms |
05-28-2012, 12:33 PM | #43 |
Newbie Join Date: May 2012 Location: cda
Can someone describe what a 60/40 chasssis setup is? Im assuming its the ratio of rear driveshaft length to front?
05-28-2012, 12:41 PM | #44 |
Close. Originally it described the link lengths. Out of 100%, 60% was in the rear (so longer) and 40% (shorter) were in the front. Compared to equal lengths, being 50/50. Now it seems to mean more about a weight balance, having 60% of the total weight in front and 40% in back. Really, it's a generic term describing a front bias, be it by links, or by weight. It's been found that shorter links are not too preferred because they scribe a different (tighter) path (arc) than a longer link will, and that simply makes things more complicated. Your front axle will act differently than the rear, and that's just one more thing to need to learn, and there's no reason for that. |
05-28-2012, 02:26 PM | #45 | |
| Re: RC Crawler Glossary of Terms
so would you recomend a 50/50 chassis set up with a 60/40 weight distribution? Quote:
05-28-2012, 02:28 PM | #46 |
| Re: RC Crawler Glossary of Terms |
05-28-2012, 02:32 PM | #47 |
also a forward bias chassis, like the mantis to name one.
05-28-2012, 11:50 PM | #48 |
thanks. drawing up plans to un-stock my crawler king. wish i would have done more research before i jumped into the crawler thing, but ive been away from the rc thing for 15 years, and a LOT has changed! |
05-29-2012, 03:45 AM | #49 | |
| Re: RC Crawler Glossary of Terms Quote:
- Steering (not on rear axle). - More weight than on the rear. - Different suspension setup (optional, but I use it to gain stability). | |
07-17-2012, 09:05 PM | #50 |
Newbie Join Date: Jul 2012 Location: Eagle Creek
What's a "Truggy"? Thanks in advance. This thread is very helpful to us brand-noobs! |
07-21-2012, 04:09 AM | #51 |
RCC Addict Join Date: Oct 2007 Location: gervais
I'll try to say it nicely but please, please use the search button if you don't know what something is, even google it if ya can. But to put it easier, a truggy is a rig that uses a frame that has been cut off behind the cab usually and tubed the rest of the way. Just type it in the search and read a way. You'll start to see the builds and get the idea of what I'm talking about
07-22-2012, 04:12 AM | #52 | |
07-22-2012, 09:25 AM | #53 |
This section is meant so you guys don't get flamed for these types of questions, that doesn't mean I can't tell you to search, that post is in all honesty is very helpful, because I did answer the question but I'm also giving advice that its a good and useful to search, 1. To not get flamed 2. It's better to take the initiative than to ask for everything
07-22-2012, 01:48 PM | #54 |
Rock Crawler Join Date: Dec 2011 Location: Las Vegas 89110
that search button is eeeevil
07-22-2012, 05:38 PM | #55 |
| Re: RC Crawler Glossary of Terms >Truggy< Buggy chassis with a truck body, and truck-sized tires. >Not a Truggy< Could loosely be regarded as a 'Tuber', but there's not much of a buggy base to it. Here's where you'd run your Tubers and Scalers. IMO, anyway. Last edited by Trubble; 01-25-2014 at 08:11 AM. |
07-22-2012, 07:09 PM | #56 | |
08-20-2012, 10:08 PM | #57 |
Newbie Join Date: Aug 2012 Location: Australia
What does fxr mean? I see it mentioned alot but not sure if its an acronym or a brand/model
08-20-2012, 11:38 PM | #58 |
| Pretty positive it's just a model name, but if it is a acronym, I'd also be interested in knowing lol but as far as I can see fx is the series and the r stands for reverse since the fx and fx pro are only forward and brake while the fx-r and fx-r pro are forward brake and reverse
08-21-2012, 02:50 AM | #59 |
| Re: RC Crawler Glossary of Terms Tekin FX-R is an ESC, often simply referred to as "fxr". Another ESC to know is MMP (Castle Creations Max Mamba Pro). |
08-21-2012, 05:43 AM | #60 | |
As to "MMP", it could also be a Castle Creations Mamba Micro Pro ESC. Either way, it's an ESC by CC. | |
RC Crawler Glossary of Terms - Similar Threads | ||||
Missing Newbie Glossary Definition | neamerjell | Newbie General | 5 | 01-09-2010 12:43 AM |
