11-11-2008, 03:29 PM | #1 |
RCC Addict Join Date: Sep 2007 Location: Port Orange
| what and why
what esc and motor do you guys use for comp and why.
11-13-2008, 07:17 AM | #2 |
hello ankbody |
11-13-2008, 07:30 AM | #3 |
RCC Addict Join Date: Jan 2008 Location: www.rccrawler.com
11-13-2008, 08:06 AM | #4 |
Rock Crawler Join Date: Apr 2008 Location: Highlands Ranch, Co.
For the speedo's either a Mamba Max or a Sidewinder, Why? Because you can program the settings for brake , both drag & stopping & Lipo cutoff & they are cheap. For the motors 55T down to a 35T brushed, Why? Because of the smoothenest (SP?) of the power & they also are cheap. A brushless motor has a high power start up & will jerk around when trying to go slow & in a bind. The only brushless system to go with is the Novak GOAT as it is made just for rock crawling but cost more & you are limited to 7 cells although some have used 8 cells with the system. Do a search in the electronics section & there is a world of info about this. |
11-13-2008, 03:35 PM | #5 |
Quarry Creeper Join Date: Aug 2008 Location: iderho
One question. Is price a factor? If not, then mamba max, or sidewinder ESC I would run a novak rooster and fifty five if you dont want to spend too much |
11-13-2008, 04:55 PM | #6 |
Quarry Creeper Join Date: Jul 2008 Location: Galt
I've never comp'ed, but my AX10 definitely crawls well. I'm running a cheap 55T motor (14T pinion/87 spur) and a Tekin FXR ESC. I got the FXR because I like its features (drag brake, lipo cutoff, etc.), compact size and the simple field-programmability; it also cost under $100. At some point I will probably get the Tekin Hotwire software, which will provide even more programming options. I don't plan to go with a brushless setup anytime soon. I'm using the 55T motor because, well, I got it for free, and it works just fine. |
11-13-2008, 05:11 PM | #7 |
11-13-2008, 05:17 PM | #8 |
Rock Crawler Join Date: Dec 2007 Location: USA
ones that work :P i havent run any comps but from what i have seen like someone mentioned if price isnt a factor then id suggest the mamba esc or sidewinder or even the goat system |
11-13-2008, 05:56 PM | #9 |
Rock Crawler Join Date: Jan 2008 Location: Eveleth
I use the Novak Rooster Crawler with an Integy 55 turn.... I have always been a Novak guy since I started 20 years ago... And I went with a 55 turn because that is what I seen most people using in their comp rigs.... |
11-13-2008, 06:03 PM | #10 |
Newbie Join Date: Nov 2008 Location: Indianapolis
11-13-2008, 06:52 PM | #11 |
thanks guys, how hard is it to program the the mamba or the sidwinder, i'm not computer wise at all . i can't even post pics. |
11-13-2008, 07:01 PM | #12 |
programming it isnt hard at all if its like most other escs...i think u mean it would be hard to tune it on the computer
11-13-2008, 07:47 PM | #13 |
i think i'm way over my head , these are the ones that you have to plug in to your computer , i think i'll just get a rooster. thanks alot everyone. |
11-14-2008, 11:13 AM | #14 |
The Rooster Crawler doesn't have an adjustable drag brake. The Tekin FXR doesn't require a computer to set it up, if that's a concern. The FXR is also available at holmeshobbies for $82, too, if you enter the promo code "ESC".
11-17-2008, 12:04 PM | #15 | |
Newbie Join Date: Jul 2008 Location: Rosedale/Bakersfield
My buddy just got the GOAT set up though, and I may be leaning more towards that, there are some areas I just need to haul over quickly and I can't do it, or when I'm playing around in dirt mixed with rock, my tires don't have any traction in dirt. (rock krushers) Also I see some parts of courses in the comps where I would need a quick jolt of speed to overcome the obstacle, and my current power with my drivetrain wouldn't cut it. | |
