11-12-2008, 08:28 PM | #1 |
Rock Stacker Join Date: Oct 2006 Location: Va Beach
| Best scale setup for Tamiya Hilux body?
I have been wanting to build a scale rig, but want to do my research first and get experienced scalers input. I basically was wondering what is the best chassis to go with for a scale Tamiya Hilux body, and get good articulation? I have been loooking at the build threads and have been getting some ideas. It would be nice to get a bruiser chassis but I cant afford $800 for it. I'm looking to spend around $200 - $400 for just the chassis(whatever a chassis kit consist of). Bare with me, i'm a bit of a greenhorn to scale rc, but any help/suggestions/input is much appreciated.........THANKS. |
11-13-2008, 08:07 AM | #2 |
alright ppl...whats goin on? 12 views and no suggestions. Someone please help me out. I want to build a 2.2 rig for trail riding. I have a couple of ideas where to start, but want expert opinions on what ESC to use and what servos stand up to a beating. Any help/suggestions is MUCH appreciated...THX again |
11-13-2008, 08:43 AM | #3 |
i make a scale chassis specifically for the hilux body. set up for 4 link or leafs. see link in sig, under custom chassis. ;) for my scalers, i run moped escs(CPE), and toward pro servos(JPs). Last edited by STANG KILLA SS; 11-13-2008 at 09:45 AM. |
11-13-2008, 09:02 AM | #4 |
'08 2.2 National Champ Join Date: Nov 2006 Location: UTRCRC
The Reign RC K2-5 works perfectly too. I'm going to be starting a new one very soon.
11-13-2008, 12:20 PM | #5 | |
| thanks for the replies Quote:
Saw the chassis, which length would u go with for the Hilux body? I havn't done much research on bodies yet, so if it comes in different sizes..I havn't picked a body size yet. I like the looks of a 2.2 rig alot. Like I said, freakin greenhorn here bare with me, i may ask some real newb Q's What's moped? Pro servos? Are CPE and JPs companies?? Going to check that Reign K2-5 now | |
11-13-2008, 12:31 PM | #6 | |
2.2 proline flatirons would look great on the hilux. moped is a cheap $30 speed control from overseas. (CPE is a fellow vendor here that sells them) toward pro servos are also cheap servos from overseas (JP customs also a fellow vendor here sells) | |
11-13-2008, 01:02 PM | #7 |
is there any sodering(<---spelling) required for a 2.2 rig?
11-13-2008, 01:28 PM | #8 |
Yes, soldering (<---correct spelling, you were close) will most likely be required for a custom build. It will be needed when setting up the electronics. BTW, I am currently building a Hi-lux with a K25 chassis. The chassis and skids can be cut (with basic tools, i.e. dremmel) to fit your needs. |
11-13-2008, 02:13 PM | #9 |
yeah, i was having a brain fart... I was wonering if you had to solder on shock towers or not? any soldering required other than eletronics?? |
11-13-2008, 03:11 PM | #10 |
On my K25 chassis, I used bolt on shock towers. Just drill a few holes in the chassis and your are ready to go! I'll snap a pic of my "in progress" build this evening, if you are interested.
11-13-2008, 03:20 PM | #11 | |
That would be great. I'de rather just use the bolt on ones anyways, beacuse I would guess they are easier to take off and clean or replace when needed. Any help I can get right now is appreciated. What length chassis is the best for the Hilux using 2.2 tires??? I've seen many different sizes on The Scale Shop's website. Last edited by Ebach; 11-13-2008 at 03:23 PM. | |
11-13-2008, 03:28 PM | #12 |
I am not sure what the wheelbase of the Hilux body is (I am building a truggy), but I am sure that the K25 will be the correct length. I set my wheelbase at 12.5" (optimal for 2.2" tires) and the chassis was a perfect length...I didnt cut anything off. BTW, your budget of $200-$400 for the chassis is pretty high. IIRC, the K25 was around $50 shipped. Last edited by JeremyH; 11-13-2008 at 03:33 PM. |
11-13-2008, 03:42 PM | #13 | |
I'm sure someone knows the demensions and would be so kind as to post them here for me Yeah, after looking around on different sites, I have learned that chassis are pretty cheap. I was kinda looking for a combo deal since this is my first build, but I think I can put one together myself. Thanks for all the input so far, I got a notebook over here writting down all the different ESC's, Motor's, axles, servo's, etc...and anything else that catchs my eye (i.e. tips and whatnot) | |
11-13-2008, 05:07 PM | #14 |
Well, I measure the length of the K25 Chassis as 16". Here are some pics of my build so far: (bolt on shock mount) (chassis....I will likely be narrowing the skids and standoffs and mouting the leafs outside of the chassis rails) (body mockup...it will be shifted forward and the wheelwell will be centered over the wheel) Last edited by JeremyH; 11-13-2008 at 05:57 PM. |
11-13-2008, 05:32 PM | #15 |
Nice! That pic of the shock mounts made it all clear for me. You said that you were going to move the leafs outside of the framerails. Does this give you better arcticulation??? |
11-13-2008, 05:44 PM | #16 |
I doubt that it will flex any different, but I am just not happy with them inside the frame rails.
11-13-2008, 06:03 PM | #17 |
just looking on RC4WD and seeen the Yota scale axles...are they worth the $200 per axle or should I just go with something like a T-rex 44 mini or 60???
11-13-2008, 06:07 PM | #18 |
Hummm....I dunno, never used them. They are cool though. Give it a go!!
11-13-2008, 06:20 PM | #19 |
Thx, but I need the opinion from someone who has used them before. But thx for everything else If they work as well as the T-rex axles, I might go with those and save some $$$ and put that towards other parts... Last edited by Ebach; 11-13-2008 at 06:23 PM. |
11-13-2008, 06:31 PM | #20 |
No problem. You wont be disappointed with the customer service from RC4WD. BTW, I am using TLT axles on the truck pictured above. |
