ecs What is a good ecs that i can use for crawling that is cheap. will use in a clod with stock motors. |
Well, first. What do you mean cheap? I wouldnt skimp on the esc and i'd buy a rooster Also, use the handy dandy search tool. |
Learn from those who have come before!! I agree...many people try to cut this corner and all find out it was not worth it. If money is the issue think of it this way, by buying a Roster Crawler ESC the first time out you will actually save the $30 or so you would be spending on frustrating crap. Another "built in" savings is that the rooster crawler will actually give descent power to your servos so you dont need a seperate BEC (battery eliminator circut) right away. Besides it's almost impossible to get the brake holding power that makes crawling fun instead of frustrating from a "normal" cheep ESC. So to sum up...shity ESC $30 +BEC $25 = $55 That basiclly shows you are only spending $30 to get the Rooster Crawler!!!! |
Ok thanks i will get the rooster |
