12-09-2008, 04:14 PM | #1 |
Quarry Creeper Join Date: Sep 2008 Location: Petaluma
| JEEP scaler crawler
Hi Anyone, I'm looking for a nice 4 point (front , rear) Jeep (preferrably 1.9 size). One that can take those BIG ROCKS that the custom "crawlers" are running over like it's leveled asphalt. I've seen the Tamiya Jeep but don't like the free coil shock system. I've seen the "New Bright" jeeps that people have converted to some pretty awesome rigs. What mfg. makes these to that type of scale and ability? What should I look at first? I want a good quality rig that's going to take what I throw at it without having a lexan body. Any help would be appreciated! |
12-09-2008, 04:23 PM | #2 |
I wanna be Dave Join Date: May 2006 Location: FOUR 8 OH
Sounds like a custom job... a New Bright hard body on top of some kind of custom chassis.
12-09-2008, 04:31 PM | #3 |
12-09-2008, 04:41 PM | #4 |
TLT's probably as they are pretty narrow, but Axial's might not be bad. As for a frame... I've seen lots of Jeep builds using K2 chassis.
12-09-2008, 05:53 PM | #5 |
RCC Addict Join Date: Jun 2008 Location: Mudville
im using a new bright 10th scale Jeep Rubi body on a Reign K5 chassis. the chassis is a bit long for the body, but i have some things going into my build that will help it out. heres a few pics of where it was a few weeks ago, its went thru a few changes recently, but generally looks close to this setup. i swapped links around so i have more rear drive shaft room, so the rear is a bit farther back adn the front is a bit more to the center of the rig now. will get pics later and post up the new setup in a day or so. |
12-10-2008, 10:07 AM | #6 |
RCC Addict Join Date: Feb 2008 Location: Hiatus..sutiaH
Wow, it is like you are wanting to build what I am, lol. Look over my build in the 1.9 forum. I just completed the chassis last night and need to post pics, but what I am building is exactly what you are after. I am making most of it from scratch because you can't buy what I want, lol. It is fun too, I like building it better than buying it. |
12-11-2008, 09:07 AM | #7 |
Quarry Creeper Join Date: Feb 2008 Location: Bay City
The k5 chassis fist awsome under the 1:6 jeep body The X trail is just to short to look right.
12-12-2008, 04:03 PM | #8 | |
Thanks for the info - KEEP IT COMING.. I kinda like the CR-01 but just did'nt think the ground clearance was good enough. | |
12-13-2008, 06:39 PM | #9 |
It looks like the 2.2's are the way to go. Does anyone have any pictures of a 1.9 and 2.2 side by side? I'm courious to see the size difference.
12-13-2008, 06:49 PM | #10 |
the main differance in a 2.2 and a 1.9 is only the Rim/Tire size. If i put 1.9 rims/tires on my jeep pictured above, it would then be a 1.9. im sure there are other small differances like axle width ect.. but rim/tire are the main things i believe.
12-14-2008, 10:41 AM | #11 | |
If so - wow! | |
