12-12-2008, 02:53 PM | #1 |
Newbie Join Date: Dec 2008 Location: Hillsdale
| Battery Question
I just got a Novak Rooster crawler esc and 55T motor. I also got an 8 cell 1500 mah saddle battery pack. In the esc instructions it says to use no more than a 7 cell battery pack. Will I do any damage running the 8 cell or will it just lead to short battery life? |
12-12-2008, 02:57 PM | #2 |
You will eventually get magic smoke and a toasted ESC. Some people say they have run it like that... but Novak says not to for a reason. |
12-12-2008, 05:19 PM | #3 |
Who's your Daddy-0! Join Date: Mar 2008 Location: Augusta
I've run 8 cell split packs on one of my 2.2's for over a year with a Novak Rooster Crawler ESC with no probs.....but with a split pack you can run them in series or in parallel and that would make a difference......
12-12-2008, 05:41 PM | #4 |
Pebble Pounder Join Date: Oct 2008 Location: Fresno
From what i've read you should be ok, one precaution you can take though is to run a separate BEC. I think the it's the BEC that limits the rooster from handling more than 7 cells. We shall see though.... my 8 cell pack should arrive tomorrow.. lol.
12-12-2008, 09:12 PM | #5 |
What is BEC?
12-13-2008, 09:11 PM | #6 |
Rock Stacker Join Date: Jan 2008 Location: Houston
I just ordered an 8 cell pack from TCS and this has me wondering. I am planning on running my a Novak Rooster 12t to start. Is there a difference between a split pack and a saddle pack?
12-13-2008, 09:15 PM | #7 |
Rock Crawler Join Date: Jul 2008 Location: Chula Vista
same thing just different name
12-14-2008, 01:56 PM | #8 |
Rock Stacker Join Date: Nov 2008 Location: W. Springfield
Its kinda like asking how many 12 ton trucks can you drive over a bridge designed to hold 10 tons before it fails. Could be alot , could be a little. I'd stick with the manufacturer's specs just to be safe.
12-14-2008, 02:18 PM | #9 |
| Battery Eliminator Circuit http://en.wikipedia.org/wiki/Battery_eliminator_circuit |
12-15-2008, 05:20 PM | #10 |
Not to ask a simple question but I was talking to an EE at work about this today and he threw out some jargon that was over my head and basically ended up it would be a crap shoot. I forgot about the article in winter 09 RCCrawler mag. I am assuming that a few of the members on this forum had some input into this. In the article called Hard Bodyz WartHOG bolt-on Tuber the auther says he used a Novak Rooster and 55t motor and a 1500mAh 8 cell 2/3A batterback from TCS Crawlers. I would assume that these guys know what they are doing, so what gives? Is this a viable combo?
12-15-2008, 05:31 PM | #11 |
12-15-2008, 06:23 PM | #12 |
| They can design stuff, guys like me have to make it work |
12-16-2008, 07:34 AM | #13 | |
An engineer might be able to design stuff, but my profession is where their knowledge and theories are derived. Last edited by JeremyH; 12-16-2008 at 07:42 AM. | |
12-16-2008, 07:54 AM | #14 | |
You will have to forgive me as electrical stuff is my weak point, I more of a mechanical and pneumatics guy. So what exactly is it that you do where you are on the otherside of an engineer than me? | |
12-16-2008, 08:04 AM | #15 |
I have a few degrees in physics and mathematics. I just reviewed the Novak Spec Sheet ( http://www.teamnovak.com/products/es...ler/index.html ) and it does list the maximum for the Rooster Crawler, which is 7 Nimh cells or 2 Lipo cells wired in series. I forgot that these were the manufacturer suggested maximums for this ESC. He is correct, with lower current draw motors, your ESC might last a bit longer than with higher draw motors (lower turn motors). BTW, it is a good idea to review the specs of an ESC before you apply power to it (which is something that I did not do before telling you above that the setup would be fine). |
12-16-2008, 09:33 AM | #16 |
