12-15-2008, 03:56 PM | #1 |
Pebble Pounder Join Date: Feb 2007 Location: Nor cal
| !!!!!!!!!!!!! .....ok so now i got my crawler running (tlt 45t motor, blah blah blah) when i get up to the rocks it goes up a little but when it get challenging the back gear (spur gear) just sits there and spins!!!!no wheel movement. whats the problem???
12-15-2008, 03:59 PM | #2 |
RCC Addict Join Date: Aug 2005 Location: VARCOR
Stock transmission?
12-15-2008, 03:59 PM | #3 |
RCC Addict Join Date: Feb 2005 Location: Minnesota
What transmission are you running? Does it have a slipper clutch? Sounds like you do and it's slipping. If this is the case just tighten it some.
12-15-2008, 04:01 PM | #4 |
stampede transmission and no slipper
12-15-2008, 04:03 PM | #5 |
09 RCA champ! Join Date: Sep 2006 Location: Acworth, Ga
are the driveshafts tight on the transmission outputs?
12-15-2008, 04:03 PM | #6 |
old style or new? if it's the old style with the plastic gears check the idler gear sounds like it may be stripped... or what he ^^^^ said.
12-15-2008, 04:04 PM | #7 |
old...what is the idler gear??
12-15-2008, 04:05 PM | #8 |
hold on lemme check "redneck"
12-15-2008, 04:05 PM | #9 |
12-15-2008, 04:08 PM | #10 |
well i just went and put it in the position where it just stalls and the spur gear is spinning but not the drive shafts....is it the shafts??
12-15-2008, 04:10 PM | #11 |
Take it apart till you find the problem, it's called tinkering!!
12-15-2008, 04:10 PM | #12 |
can you tell if the outputs are spinning?
12-15-2008, 04:13 PM | #13 |
i took out the whole tranny just now and the shafts are on tight so it wasnt the problem...what else??the idle gear? oh and i dont like tinkering! takes a long time |
12-15-2008, 04:18 PM | #14 |
12-15-2008, 04:22 PM | #15 |
Quarry Creeper Join Date: Sep 2008 Location: So.Orange County
Sounds like it might be the internal slipper, pull the trans apart and replce the plastic gears inside ONLY THE PLASTIC ONE!! then put it back together remembering what screws went where, that should solve it |
12-15-2008, 04:22 PM | #16 |
not exactly...i spent all yesterday and the day before "tinkering" and i didnt get anywhere...i thought it was about time to ask some people who knew something about crawling, and see if they knew other that wasting more time |
12-15-2008, 04:25 PM | #17 | |
ok which one is the internal slipper?? and what do you mean by "the plastic gears inside, ONLY THE PLASTIC ONE" that doesnt make sense to me | |
12-15-2008, 07:38 PM | #18 |
Actually open up the transmission, and take a look at what is inside. Then report back with your findings. What were you tinkering with for two days? Odds are you haven't locked the slipper. |
