01-03-2009, 02:50 AM | #1 |
Rock Stacker Join Date: Oct 2008 Location: oahu
| rooster esc
anybody know the max voltage i can run with this esc.....i was thinking a split cell 8 pack at 9.6 volts from tcscrawler.com.....will i ruin it....thanks guys....
01-03-2009, 02:58 AM | #2 |
Rock Stacker Join Date: Dec 2008 Location: Calgary-Canada
Input Voltage (1.2VDC/cell) 6-7 cells Case Width 1.63 inches Case Depth 2.02 inches Case Height (w/h.sinks) 1.22 inches Weight (w/heat sinks) 3.00 ounces On-Resist.–Fwd. (@Trans) 0.018 W On-Resist.–Rev. (@Trans) 0.018 W Rated Current–Fwd. 100 amps Rated Current–Rev. 100 amps Braking Current 100 amps Rev. Delay (after Smart Braking) Zero Sec. BEC Voltage 5.7 volts DC BEC Current 0.5 amps Power Wire 16G / 6” Signal Harness 26G / 6” Transistor Type MEGAFET PWM Frequency 1250 Hertz Motor Limit Mild Modified Part Number 1850 This should help |
01-03-2009, 03:03 AM | #3 |
RCC Addict Join Date: Jun 2008 Location: Fresno
factory specs say 7 cell max but if your willing to void your warentee ive seen some people running w/ 8 cells w/o problems |
01-03-2009, 06:44 AM | #4 |
Sixth time this week this same question has been asked. Unbelievable.
01-03-2009, 07:58 AM | #5 |
I wanna be Dave Join Date: Aug 2008 Location: cape crud... will you be my friend
some people must have gotten parts for xmas. i love the sarcasm here. suprised nobody gave a link to the search. Last edited by crunky; 01-03-2009 at 08:00 AM. |
