Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Droop set up for ax 10 rtr
Old 01-03-2009, 01:52 PM   #1
Default Droop set up for ax 10 rtr
How do I set up droop on my AX 10 RTR I have no clue how but want to to lower its height and limit torque twisting. Thanks
AXE 10 is offline   Reply With Quote
Old 01-03-2009, 02:01 PM   #2
There is a thread here about lowering the Ax10. Just do a search for it.
1SLOW64 is offline   Reply With Quote
Old 01-03-2009, 05:05 PM   #3
Was curious about this myself, so I took your advice, and did a search, but really came up with nothing. Can you post the link for the thread you found in your search results?
syber70 is offline   Reply With Quote
Old 01-03-2009, 05:18 PM   #4
Ya I checked to and got nothin.
Old 01-03-2009, 05:27 PM   #5
If you want to limit torque twist the best thing that I did was to 4 link the stock 3 link if you have not already done so
If you want to lower it with out droop you can buy some shorter shocks like the losi 4 inch crawler shocks plus there better and smoother than stock
Hillcrawler is offline   Reply With Quote
Old 01-04-2009, 11:48 AM   #6
Default Hmm..
I have stock shock towers with 45 weight oil in em. I love it.. And i found some traxxas t-maxx 2.5 springs. stretched em a bit. and now my articulation is around 170 Degrees..
sowhatim14 is offline   Reply With Quote
Old 01-04-2009, 11:58 AM   #7
TEAM MODERATOR
Reflection's Avatar
From the entire board,searched the word droop....300 hits
http://www.rccrawler.com/forum/searc...searchid=23200
From the Axial section alone.....300 hits
http://www.rccrawler.com/forum/searc...searchid=23212
Happy reading.
bout 40-50 is all you need.
Reflection is offline   Reply With Quote
Old 01-04-2009, 07:46 PM   #8
Default droop internal springs
You can get some internal springs, (tcs sells them). They go inside your shock body under the valve. They will fit in stock axial shocks, but I was popping the caps off mine before I put them in droop so I just bought different shocks and drooped them. Hope this will help some.
drnedatsnov is offline   Reply With Quote
