01-04-2009, 10:41 PM | #1 |
Quarry Creeper Join Date: Jan 2009 Location: Sandpoint
| wheel weight questions
can u use wheel weights on the stock wheels????? And how do u install them??? I really want to get some |
01-04-2009, 10:53 PM | #2 |
Rock Stacker Join Date: Jan 2009 Location: Grimshaw
What kind of crawler do you have? You install the weights by taking off your tires and put them on the outside of the rim. It depends which crawler you have but I took my stock axial rock lizards and used nickels glues together and that works awesome and they fit perfect. I don't know if you have the same size of wheels though. Most people use wheel weights for cars.
01-04-2009, 10:56 PM | #3 |
Newbie Join Date: Jan 2009 Location: Kelowna
throwing some lead BB's can work as well, I know in 1:1 they use lead shot
01-04-2009, 11:48 PM | #4 |
Quarry Creeper Join Date: Sep 2008 Location: Where there are no rocks.
use sticky wheel weights for cars/trucks. I used them on my MRC and AX10, just pull the rubber off and the foam, peel and stick, don't cover the holes in the rims. Reinstall rubber and foam and your off to the races, or rocks i guess.
01-05-2009, 08:09 AM | #5 |
ok thanks ya i forgot to say i have a losi mrc and i guess ill try the sticky weights......... where can i get these????
01-05-2009, 12:49 PM | #6 | |
Newbie Join Date: Jan 2009 Location: New Orleans
I am a rccrawling newb too, but not new to the RC world or rock crawling as I have two 1:1 rock crawlers. | |
01-05-2009, 01:50 PM | #7 |
Pebble Pounder Join Date: May 2006 Location: Anaheim
do you run weights in all four tires? or just front or just rear?
01-05-2009, 02:20 PM | #8 | |
FYI, if you run the battery on top of the chassis, than you should run weights on both ends of the rig. I would aim for 60/40 split and try smaller amounts first, than add to it as needed. I wouldnt put anymore than 5-6oz in each front wheel and 3-4oz in each rear wheel for starters. Remember you are adding rotating mass and it can start causing broken parts if you put on too much weight. | |
01-06-2009, 02:57 AM | #9 |
I run 3.5oz in front and 1.5oz out back in my MRC And 6oz up front and 3oz out back on my Ax10. Seems to do the trick, maybe some more in the front would help a bit. |
01-06-2009, 06:55 PM | #10 |
Pebble Pounder Join Date: Feb 2008 Location: here
I run 6oz. in each front tire of my ax10. In the rear I have 3oz. in each tire. It crawls well. I use lead solder. You take what you need and wrap it around the outside of the rim and duct tape it. I hear the stick on wheel weights are a bear to try to remove. Don't forget to star cut your tire foams also. That makes a little bit of difference. |
01-07-2009, 09:55 PM | #11 |
Rock Stacker Join Date: Dec 2008 Location: Kalamazoo, MI
I got the stick on weights from the tire shop too. They just gave them to me after some prodding, at first they wouldn't even sell them to me because they're lead (toxic). Finally he was like, here but you didn't get them from me. BTW I only have about 1.5oz on each wheel on my MRC and it seems to be enough, that's as much as one wrap around the wheel without covering the vent holes. Also on MRC's you have to trim the weights because they are too wide, a pair of wire cutters works great.
01-14-2009, 08:09 AM | #12 | |
