01-24-2009, 07:22 PM | #1 |
Newbie Join Date: Jan 2009 Location: Phillipsburg
| Proper weight question...well sort of...
I've been thinking today whether I want to go with a tuber or a scaler, and than I got to thinking which one would actually be better weight wise for the rig. Which one would be?
01-24-2009, 07:37 PM | #2 |
Pebble Pounder Join Date: May 2006 Location: Anaheim
Depends on what the tube was.
01-24-2009, 07:43 PM | #3 |
01-24-2009, 09:36 PM | #4 |
RCC Addict Join Date: Jun 2008 Location: Mudville
the occasionaly top heavey weight of a tuber can be typically compensatd for with some wheel weights or smart setup of your battery and elects. but obviously it will vary a bit by tuber depending on if its solid or tube, or a combo of. from what i have seen here on the forum and in person (i dont own one) the Edge can be a good unit, but like any tuber, requires a bit more attention to setup for a smooth rig with a good balance. but for ease of setup and balance, where weight is considered, a comp rig type chassis usally has a bit of a cog advantage over the typical tuber. and getting a good balance out of a tuber isnt nearly as impossible as some would think it is. yea its tricky but very possible. this is balanced only on the rear two tires, and i would estimate is holding it at around an 80* angle, mabye a Tad bit less, but not very much. Last edited by Timmahh; 01-24-2009 at 09:46 PM. |
01-25-2009, 12:57 PM | #5 |
Rock Stacker Join Date: Sep 2008 Location: cumbria
im just about to invest in a tcs edgee chassis myself |
