Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: Shock oil
Old 02-01-2009, 07:31 AM   #1
Question Shock oil
Shock oil what weight should I run . I'm thinking about running inner and outer spring's has anybody tried this I'm running ax10 with axial alum.threaded shock's
blacksmith is offline   Reply With Quote
Old 02-01-2009, 07:54 AM   #2
Why inner and outer springs? That will make your shocks too stiff...
Start with 30 or 40 weight oil...
JeremyH is offline   Reply With Quote
Old 02-01-2009, 09:15 PM   #3
Get the losi shocks they work great. I run losi with 35w f 65w r. Use these ends for the shaft- losi# LOSA6044-Mount the shocks upside down. Large part of the shock down on the axle. Matt
SDheavymetal is offline   Reply With Quote
