02-01-2009, 02:49 PM | #1 |
Pebble Pounder Join Date: Dec 2008 Location: MIDDLE TN.
| Slack in the front and rear end
Anybody ever tore out gears ,lockers, or axles?Mine has a lot of slop,don't know what it is that is wore. JEFF |
02-01-2009, 03:02 PM | #2 |
02-01-2009, 04:32 PM | #3 |
Quarry Creeper Join Date: Apr 2008 Location: Fondy, WI
most likely the locker... upgrade it and you'll be all good.
02-01-2009, 05:47 PM | #4 |
Pebble Pounder Join Date: Jan 2009 Location: Crestview
i have tried several different methods fo fixing the slop in mine. different lockers, shimming, axles. where it is coming from is where the axles goes into the locker. the tolerances are not tight enough. when i started i had about 3/4" of wheel movement, now i have it down to 1/4" or so. this is measured by rocking your rig back and forth. no motor just slop in the axles. the only way to get around it is, worm drive axles. but they are $500 for a set of 2. i have better than $1200 into this already. and the girlfriend calls it a toy. |
