02-03-2009, 04:02 AM | #1 |
Quarry Creeper Join Date: Jan 2007 Location: Las Cruces, New Mexico
| ax10 trans queston
i dont know where else to post this but if any of you guys have a ax10 trans and a stealth trans do you know of all the gears are the same or not? im thinking of buying the dig that skrc makes for the ax10 and trying it but i need the output shafts and the gear they go on befor i even do it.
02-03-2009, 03:32 PM | #2 |
nobody knows?
02-03-2009, 03:41 PM | #3 |
I wanna be Dave Join Date: Mar 2008 Location: Pacific Ocean
So are you thinking of trying to put a CKRC dig on a Stealth transmission?
02-03-2009, 03:54 PM | #4 |
yep thats what i was thinking
02-03-2009, 04:19 PM | #5 |
The CKRC dig is not a bad dig, but takes quite a bit of adjusting and modifying to make it work smoothly. It would compiicate things even more rigging it to work on a stealth transmission. My advice is to get a R2D from RC4WD for $60. Trust me, you will end up spending more $ if you travel down the path you are thinking of.
02-03-2009, 04:38 PM | #6 |
i got an r2d comeing in atm i just wanted to see if this would even work tho i know i would have to mod the mounting plate but all i need to know about is if that gear for the output shafts would fith in the stealth trans
