02-03-2009, 05:54 PM | #1 |
Rock Crawler Join Date: Sep 2008 Location: Bakersfield
| some advice needed
ok guys.. i am torn between getting a scx10 or arr ax10 and x-trail chassis and buying some 1.9s. give me your advice.
02-03-2009, 07:39 PM | #2 |
go with whatevers cheapest. the end result is pretty much the same.
02-03-2009, 09:53 PM | #3 |
Newbie Join Date: Jan 2009 Location: ardmore
i think the scx 10 would be cheaper but with the other route you would get to pick different tires. say if you want slingers instead of flat irons
02-03-2009, 10:15 PM | #4 |
Rock Crawler Join Date: Nov 2007 Location: San Bernardino
no question bro.... SCX10!!!!!!!!!!!! for the win! |
02-03-2009, 10:31 PM | #5 |
Rock Crawler Join Date: Jun 2006 Location: Wisconsin
I'd have to agree. I don't think it matters what you start with, if you want a scale truck. You'll get it quicker, probably, with the SCX-10, versus building a scale truck out of an AX-10, with an X-Trail chassis. If you intend to run larger 2.2 wheels or tires, then you'll have to make sure they will fit on an SCX-10 before you choose that truck. I'm not sure what the clearance is on the SCX-10, but if you don't want to run wideners, with 2.2 tires, then you might be better off with the X-Trail.
02-03-2009, 11:50 PM | #6 |
Quarry Creeper Join Date: Apr 2008 Location: Fondy, WI
save urself some money, get a used ax10 thats ready to run for cheap, then with the money you saved- buy the x-trail and shocks, etc. that way if you ever wanna comp, you can swap it out and already have the stuff to run it.
02-04-2009, 12:25 AM | #7 |
well the thing is, i already have a 2.2 comp..(see sig) but i still only have the rock lizards..i was thinking that i could use the 2.2 wheel stuff for that truck. but the scx10 does have the 1.9s already and i plan on using/ having rock creapers, crushers, slingers, and flat irons...and different beadlocks like the mojave or true scale ones with blue rings... so now you guys see my whole delima. lol
