Go Back   RCCrawler Forums > RCCrawler General Tech > Newbie General
Thread: How i drooped it...
Old 02-09-2009, 10:11 AM   #1
Default How i drooped it...
I have an AX10 RTR.
the springs that came w/ it sucked.
i did a lot of research on "Droop" and decided to do a partial droop/internally sprung set up.
i found a place that has all the springs you would ever need.
i put the smaller (slightly stiffer) spring under the piston (Droop spring) and the longer spring over the piston (inner sprung)
here is a completed shock next to the springs.
I FREGGIN LOVE IT! makes the suspension 10x better, and helps keep 4 wheels on the ground!!!
i figured it would help some to show what im talkin about.
(OHH OHH! action shot bonus!)
BEELZEBOB is offline   Reply With Quote
Old 02-09-2009, 11:28 AM   #2
Who had the springs?
sickness is offline   Reply With Quote
Old 02-09-2009, 11:40 AM   #3
yes you never listed where the springs were from
Scottish is offline   Reply With Quote
Old 02-09-2009, 11:53 AM   #4
its a local hardware store called McGuckins.
they have hundreds of lil springs, and all the 3mm screws and locknuts you could ever want!
home depot had nothin.
Old 02-09-2009, 12:06 PM   #5
yes home depot and other stores similar have very limited metric selections especially when you get into the smaller sizes
Old 02-09-2009, 12:13 PM   #6
yea, im totally stoaked.
i did a full droop initially, but hated the belly draggin.
i mean really, i wanted to get softer external springs. but no LHS w/in 30 miles has them.
so, i went this route, and was able to improve my COG, and improve the suspension.
i just need some heavier oil, and this will be perfect.
(i also greenslimed the o-rings @ the bottom.)
Old 02-09-2009, 12:35 PM   #7
is this hw store a DYI or ACE store perhaps some home brew Chain store?
Timmahh is offline   Reply With Quote
Old 02-09-2009, 12:52 PM   #8
its a local store only.
the McGuckin's are a local family (played rugy with, and football against one of the kids in highschool)
99% sure that there is only 1.
they have like 2 isles devoted to lil metric screws, springs, and stuff. Boulder crawlers are just lucky i guess!
Old 02-09-2009, 04:17 PM   #9
what size are the springs?
dale3311 is offline   Reply With Quote
Old 02-09-2009, 05:17 PM   #10
Do you have pics of what you did?
Grump is offline   Reply With Quote
Old 02-10-2009, 10:50 AM   #11
the long spring is like (approx) 2", and the short ones is 1"
no pics of what i did, but i can walk you through it.
i removed the shocks.
unscrewed, the top, drained oil.
used a pair of pliers and a papertowel to grasp the shaft and unscrew the bottom ball end.
remove shaft, and external spring.
now with the shaft seperated from the shock body, the shaft has a piston @ the top and a black spacer under the piston.
I removed the spacer, and put the smaller spring under the piston, then put the spacer back on the shaft under the spring ( i tried it with the spring under the spacer, and didnt like it. the way i have it slightly reduces the articulation, and the shock from bottoming out)
then i put the shaft back in the shock body, and screwed on the ball end.
Then, i pulled the shaft as far through the body as it will go, centered and droped in the longer spring.
checked that all is centered, filled w/ 100 weight oil, capped the top, and PRESTO!
a semidrooped, internally sprung shock!
