02-12-2009, 10:41 PM | #1 |
Newbie Join Date: Feb 2009 Location: Menasha
| Crawler q's...Losi crawler
I plan to get into rock crawling soon. I'm no newbie to R/C, but have never pulled the trigger on a rock crawler yet. I plan on waiting for the Losi to come out. My first question is what to use for a motor, being that it is worm drive, and lower geared than most. Would a Velineon 3500 be okay, or do we want something with more torque, and less speed yet? I assume, being worm driven, you won't need a drag brake, which allows more choices for an ESC. I also don't quite comprehend the whole dig thing. I understand that it allows tighter steering, but not how to use it, or exactly how it works on the Losi. I am also looking for suggestions for TX/RX. I assume any 3 channel would work, but what would work well on a budget? I have been doing some searches here.........quite a bit of info to be had. Still.....I have to ask. Thanks in advance |
02-13-2009, 07:02 AM | #2 |
You will probably want something with more torque. That is a horsepower motor that works well in bashers, but probably wont in the Losi. Also, your assumption is correct, you likely wont need a drag brake, however, the Castle Creations Sidewinder (which is my ESC of choice) has a programmable drag brake (if you purchase the Castle Link). As for the radio system, the DX3R is a good choice.
02-13-2009, 09:59 AM | #3 |
Pebble Pounder Join Date: May 2006 Location: Anaheim
As for motors there are really in my oppinion two schools of thought. Lots of torque and low RPM (similar to a diesel American truck) don't have to gear down as much. or Lots of RPM (similar to a 4cyl gas Toyota) gear down way down. Since we are dealing with itty bitty toys, I prefer the latter, it helps smooth out the throttle response. |
02-13-2009, 10:36 AM | #4 |
The recommended motor from Losi is a 17.5T, a high-torque, high-turn crawler motor would make this thing painfully slow. It developes its torque through the speed of the motor, not by the low-end grunt of the motor itself. No drag break is required, the only way the worm gears will turn is if there is power going to the drive shafts.
02-14-2009, 02:42 PM | #5 |
:-(:-(:-( The truck has been pushed back to May.... -x |
02-15-2009, 02:28 PM | #6 |
Pebble Pounder Join Date: Feb 2009 Location: Cda, Idaho
How about something like a Holmes 35-45T (P-94) motor or maybe a puller motor. I am also going to buy one of the Losi's (in flippin May) and am having the same problem with the motor choices. I want a fair amount a wheel speed but probably not as much as a 7T cobalt puller.
