03-05-2009, 03:38 PM | #21 |
Newbie Join Date: Feb 2009 Location: highland
well 2 more days until i get the chassis...cant wait...
03-08-2009, 08:03 PM | #22 |
Pebble Pounder Join Date: Dec 2008 Location: uhh,,, i forgot
nice , i just built mine yesterday , its not that hard to setup as long as you have all the rod ends
03-10-2009, 01:01 PM | #23 |
Rock Crawler Join Date: Jul 2008 Location: Chula Vista
Like Gunnar said earlier. I actually make my own lower links also using Delrin. Slides a whole lot better than Aluminum.
03-10-2009, 01:51 PM | #24 |
03-12-2009, 02:35 PM | #25 |
well my chassis came in today, still have to finish out the workday, before i can go out to the shop and pick it up. im going to get the dig tomorrow along with the new radio...im looking for some metal rod ends, so if anyone has any leads on some it would be greatly appreciated...
03-13-2009, 11:47 AM | #26 | |
03-14-2009, 09:53 PM | #27 |
ok so my LHS didnt have the correct servo for the dig, (the 225mg) i purchased the dna 300 i believe.but i have a spare 645mg, can i use the 645 for this? i have the ace rc ds1015 that i am going to use for the steering servo...but my only other spare that i have is a futaba s3003...should i fab my own servo plate and just use the hitec 645mg? thanks for the help...
03-14-2009, 10:35 PM | #28 |
Quarry Creeper Join Date: Dec 2008 Location: Punta Gorda, Flo-rida
The 645 will work just fine thats what im running, look around on the forum for swx builds, it should be easy to find a thread with a dig that has a standard size servo.
03-15-2009, 01:42 AM | #29 |
03-16-2009, 10:51 AM | #30 |
having troubles with the dig....but soon enough ill have it all put together!
03-16-2009, 04:27 PM | #31 |
ok so i have the dna dig and am confused as hell, not sure how it is supposed to go on...searched everything i could think of and still have no luck with instructions to set it up...is there something i am missing? any help on this subject? is there another piece i need to put the puzzle together? i have the stock ax10 tranny...thanks again for the help!!!
03-16-2009, 07:48 PM | #32 |
On the right you will see a DNA dig install instrauctions. Also there is piece for setting your epa's http://www.dna-rc.com/main.html |
03-23-2009, 07:14 PM | #33 |
| now i just need to figure out where i am going to mount all the electronics.... |
03-23-2009, 08:41 PM | #34 |
Make a plate to go on your upper links and zip tie. Your axles are on the wrong way or tranny is wrong. You have it setup for a front dig not a rear dig. |
03-23-2009, 10:33 PM | #35 |
thanks for the heads up ill swap the axles around tomorrow...
03-24-2009, 01:09 AM | #36 |
Ex Nor-CalRCRC slave Join Date: Dec 2008 Location: San Mateo, CA.
just leave them there, they'll be fine... J/K man looks good so far, move the dig servo behind the motor if you have room(after you switch things around)
