03-10-2009, 12:40 PM | #1 |
Newbie Join Date: Dec 2008 Location: CAMERON PARK
| recommended esc's
Hi new to rock krawler rc's and am putting togther an ax-10 from parts that have been donated by friends and some stuff that I have bought. Looking for suggestions on an affordable speed controll that will do the job and not break my pocket book time. Ecomony sucks!!!!!! Do prefere a fairly quick reverse. Thanks |
03-10-2009, 12:43 PM | #2 |
Newbie Join Date: Dec 2005 Location: Citrus Heights
the novak rooster seems to be a popular pick
03-10-2009, 01:26 PM | #3 |
I wanna be Dave Join Date: Oct 2006 Location: Centered
Tekin FXR is a solid choice as well. Tekin has software updates coming very soon to tune the throttle response a bit better, but even out of the box it's a great little speedo. Very small footprint and direct solder posts make it easily installed in any rig. I run them in my 2.2 and my Losi MRC. http://rccrawler.com/forum/showthread.php?t=105316 |
03-10-2009, 01:59 PM | #4 |
thank you I'll check it out.
03-10-2009, 02:02 PM | #5 |
That sounds like a good way to go also. Since it's lunch time, I think I'm gonna run with that suggestion over to the local hobby shop and see what I can come up with. Thank you much appreciated |
03-10-2009, 02:23 PM | #6 |
Rock Stacker Join Date: Jan 2009 Location: Toronto
I've got a Mamba max and think it's great. Not on the cheap end though. Whatever you get - just make sure it has drag brake.
03-10-2009, 02:31 PM | #7 |
I completely forgot about the Tekin and Mamba, good choices also
03-10-2009, 02:35 PM | #8 |
Good call on the drag brake, totally forgot about that. Thanks |
03-10-2009, 02:51 PM | #9 |
Quarry Creeper Join Date: Feb 2009 Location: ewetah
I run the Tekin FXR with a 45t and I love it. Very resonably priced and easy to use
03-10-2009, 03:25 PM | #10 |
I'm running a 45t with a 16 tooth drive gear and it does seems to work well. The Tekin and the Momba both seem to do very well. How is the drag brake on that Tekin, does it work well??
03-10-2009, 03:31 PM | #11 |
Quarry Creeper Join Date: Apr 2006 Location: 5280
03-10-2009, 03:32 PM | #12 |
Quarry Creeper Join Date: Oct 2008 Location: Spanaway, Wa
Yep.....I just put a Tekin FX-R in my tuber....it's great. Easy setup. You can change alot of parameters, including the brake, with the onboard programming buttons.
03-10-2009, 03:58 PM | #13 |
03-10-2009, 04:42 PM | #14 |
Rock Stacker Join Date: Feb 2009 Location: Sunset, Utah
03-10-2009, 05:02 PM | #15 | |
That's where the Tekin has the upper hand over the Castle ESC's. Even at full tilt the Castle's still have some free roll depending on the weight of the rig. Some drivers like that, but I'd still take the Tekin and program it that way, rather than just settle for it with the Castle's. | |
03-10-2009, 05:22 PM | #16 |
Rock Crawler Join Date: May 2007 Location: Norwich
I have experience with the LRP (maybe good for scale but not a comp esc), the Rooster Crawler and the Mamba Max. The Rooster is a good plug and play (and only play with what we tell you to play with ie 2C lipo max) esc. It has a great drag brake and what seems to be a linear throttle curve (and will cost you about $85-95). The Mamba ($110-140) is completly adjustable (assuming you have the link) in both throttle and brake curves (you need a computer to do this) and it can handle more than a 2C lipo. Maybe a bigger concern. I ran my rooster on a 2C lipo with a 333oz steering servo and a 160oz dig servo with no problem. With the Mamba I HAVE to run a BEC (this adds roughly $20 to the equation) Ask yourself what you want to do? if that falls within The Roosters specs go with the Rooster, if you think you want to do something different in the furture go with the Mamba and upgrade software when needed. You might also find what your looking for in a Castle Sidewinder? I've owned 2 Tekin Rebel 2's and both burnt out within 8 months? So I'll only comment on the Rooster and the Mamba. Hope this helps |
03-10-2009, 10:04 PM | #17 | |
03-10-2009, 10:06 PM | #18 | |
Thank you | |
03-10-2009, 10:13 PM | #19 |
03-10-2009, 10:15 PM | #20 |
and, the economy doesn't suck if you are a tranny guy! I got $$$ for all of my toys! not! |
