Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: LTL??? Goliath???
Old 10-02-2005, 06:05 PM   #1
Question LTL??? Goliath???
I was wonderin which you guys would recomend? The TLT or the Goliath? What advantages does one have over the other? I dont see many Goliaths around on these forums, but many TLT's any advice would be helpful. Thanks
JL
johnathanlopez is offline   Reply With Quote
Old 10-02-2005, 06:45 PM   #2
31st place in 2006 Nats!!
toyofast's Avatar
First look at the price between the two.... $80 vs. $180. Right there makes and breaks most people. Plus the TLT has a lot more hop-ups in th aftermarket world while the PTI is a mix-n-match type of truck. Parts are a lot easier to come by for the TLT.... and most everyone that builds a 2.2 truck has TLT axles.
toyofast is offline   Reply With Quote
Old 10-02-2005, 06:57 PM   #3
JL
just like you said, you see many TLT's. TLT's have the most aftermarkets parts available, and people have figured out how to make really good crawlers with TLT parts for very cheap.
gregrocks90046 is offline   Reply With Quote
Old 10-02-2005, 08:08 PM   #4
On the other hand, the Goliath is allready a good crawler, and with a few mods using most of the stock parts it could be just as good as the TLT. I think it's like the TXT vs Clod thing w/ the Goliath being the TXT and TLT being the Clod. The difference being the starting price and finding parts for the Goliath.
Mazlem is offline   Reply With Quote
Old 10-02-2005, 08:16 PM   #5
Hummm....... Which functions better for rock crawling? Cantelevers or straight shocks? Anyone have pics of a Goliath setup for rock crawling? It looks capable. Thanks guys
JL
Old 10-02-2005, 09:54 PM   #6
Straight shocks are better for crawling. I think there's pics or a link to a modded one here somewhere. If not there's one or two at one18th.com. I don't think I've seen somebody put shocks to the Goliath axles yet.
Old 10-02-2005, 10:00 PM   #7
Ive never seen a TLT but a bud of mine just got one so ill look at it and see what i think.... Ill probally go with it simply becuase of the amount of things i can find out about them, and avaliability of parts . Although i like the tc3 stuff on the Goliath.... Maybe ill buy both!
Old 10-02-2005, 10:54 PM   #8
I actually plan to do that too.. but not until my tuber is completed.. I think it will be much better..
Speed Demon is offline   Reply With Quote
Old 01-13-2006, 08:19 AM   #9
Post
can so,mebody telll me all the hop ups fora tlt?? i have a stock tlt and know of no hop ups some body help
TLTBASHER is offline   Reply With Quote
Old 01-13-2006, 08:46 AM   #10
Keep in mind the Goliath has TC3 diffs, plastic ring and pinions and balldiffs... that right there would turn me away from a crawler!
but it looks like a cool little truck...
Later,
Jake
JakeDaSnake is offline   Reply With Quote
Old 01-13-2006, 08:48 AM   #11
DEE
search buton on the top of the page !!! I am new to all of this to, but buy spending some time looking and reading you will figure it out. If you need help when you start biulding read some more!!! There are also stickys on top of the main forum page klick on how to biuld a tlt it will tell you all you need to know good luck
DEE is offline   Reply With Quote
Old 01-13-2006, 10:08 AM   #12
I don't own a Goliath nor have I seen one in person so I really can't give my opinion on the truck but the TC3 diffs are pretty stout if you get the steel out drives, stout enough to withstand a low turn mod motor for 5+ minutes of abuse through qualifiers and mains for an entire season of racing if not longer. And spools are readily available with the steel outdrives for a reasonable price.
gone_wheelin is offline   Reply With Quote
Old 01-13-2006, 03:38 PM   #13
Get off my lawn!
microgoat's Avatar
The Goliath definitely has potential, but in the same way a TLT does. You buy the kit and throw away everything but the axles. $180 is pretty steep for a pair of axles in anybody's book. One nice thing about the PTI is that you can use a Stealth tranny and the driveshafts will mate up to the axles, since that's the way it comes from the factory, with CVD's no less (at least the one I saw had CVD's; they might have been added by the builder).
I'd like to do a Goliath chassis, just for the halibut. I know there's not that many of them out there. Maybe the way to go would be to build it as a scale rig. I could easily modify my Barnyard Buster's skidplate to accept the AE tranny.
Now you're talking spendy, take a $180 truck and throw another $250 into the chassis, and it's still not RTR.
microgoat is offline   Reply With Quote
