03-29-2009, 09:52 AM | #1 |
Quarry Creeper Join Date: Feb 2009 Location: Richmond, VA
| Servo/Steering Problem
I have attempted to zero my servo and radio. ( I took the servo horn off, turned on my crawler so the servo would return to zero, I centered my radio trim and then turned on my radio. My tires would be centered after this centering process.) However every time I turn on my crawler my tires move to the left a small amount. Then when I turn on my radio the tires return to zero. I was wondering if this is normal? Also, if I leave my radio off and turn my crawler on several time my tires will move to left more and more each time I turn on my crawler. Is this normal? My tires will return to center when I turn on my radio. Any help would be appreciated at this time. |
03-29-2009, 10:27 AM | #2 |
Quarry Creeper Join Date: Jun 2006 Location: Folsom
I have several that do this more or less so it seems pretty normal to me. I wouldn't trip on it.
03-29-2009, 10:29 AM | #3 |
Newbie Join Date: Feb 2009 Location: rathdrum idaho
its either your wheels are weighted wrong or you arms are stripping |
03-29-2009, 10:36 AM | #4 | |
What arms are stripping? My servo arm? If so what can I do to prevent the issue or do I need to just get a new servo? I am using the standard Axial RTR servo. | |
03-29-2009, 12:26 PM | #5 | |
Rock Crawler Join Date: Aug 2007 Location: Columbia, TN
Nothing is wrong with it. There's a failsafe built in to most receivers for just in case the receiver loses the signal from the transmitter. You can set it where it's perfectly center, but for the most part I wouldn't worry about it. It's always a better practice to turn the transmitter on before powering your rig, and also not to turn the transmitter off until after you've removed power from your rig. Do that and you'll never notice the problem. | |
03-29-2009, 01:04 PM | #6 |
Thanks for the information and for not bashing me for my newbie question. No where in my Axial manual did it say how to power up the crawler and radio. Never thought to ask if there was a power up sequence.
03-29-2009, 03:39 PM | #7 | |
Not that it has to be done this way, but it's just always good for the most part. I just remember back in the days when if the receivers had a fail safe, they sure didn't work, hooking up the battery and having my r/c jump out of my hand and take out down the road on it's own. And this is the newbie section, so for the most part nobody should be bashing anyone in here for asking a question. | |
03-29-2009, 06:54 PM | #8 |
Quarry Creeper Join Date: Mar 2009 Location: Surprise, AZ
Just as a standard practice you should always be turning on your TX before your RX. If you turn on your truck first and it decides to bind up or someone is on your freq it will take off on its own for ya, or drive a servo to an end point it shouldnt be and breaksomething etc... TX then RX an you won't have the servo issue either. |
