04-05-2009, 10:15 PM | #21 |
Quarry Creeper Join Date: Feb 2009 Location: Richmond, VA
Wholy crap. That was the best explanation of anything I have received since I have joined this forum. SWX chassis and Losi Shocks $150+ dollars. Using spacer to reduce COG, priceless. I will get an SWX and Losi shocks as soon as I can get the money. Tough times in this economy. Once again thanks.
04-05-2009, 10:19 PM | #22 | |
I have a 4 link set up on my crawler. Are you telling me now I have to do geometry in order to get my crawler its best COG? I have an 8 pack battery on the front axle. I have moved my ESC and Receiver to the top links. Should I have moved any of this to a different location to improve my link geometry? Please explain in simple terms if possible or post a hyperlink to a thread I can read to learn more about this link geometry. Thanks for responding to my post. | |
04-05-2009, 11:05 PM | #23 | |
04-06-2009, 04:31 AM | #24 |
Newbie Join Date: Mar 2009 Location: Denver
i just bought a set o losi shocks for my artr and they made a huge difference in the smoothness and lowered the center of gravity a bit as well
04-06-2009, 05:30 AM | #25 |
The chassis werent listed in any specific order. I just listed the chassis I knew about off the top of my head. Sorry for the confusion, but thanks for the heads up on the Hellstorm chassis. I am very interested in your Warrior 2 35T engine. Will contact you once I get this COG situation under control. |
04-06-2009, 05:32 AM | #26 |
04-06-2009, 08:32 AM | #27 |
First thing you need to do is have your Front Wheel/Foam/Tires weight from 12oz-16oz each... The Rears anywhere from 10oz-12oz. Do this first and report back. Next Step will be choose a Chassis that lets you pick a better performing Shock and a better link arrangement. |
04-06-2009, 12:46 PM | #28 | |
Wheel - Proline Racing 2.2 Eight Shooter Beadlock Wheel: 3.2 oz each Tire - Team Losi Rock Claw 2.2 tires: 4.3 oz each Foam - Proline Racing 2.2 Oversized Rock Crawling Memory Foam: 1.6 oz each Weight - Stick on weight: 4 oz Total of 13.1 oz per wheel. If my calculations are correct? These weight are based on the weights listed on the TCS website for two of each so I cut the weight in half for the calcuations. I dont know what to look for to evaluate a chassis. All I know is that a chassis should have a lot of holes for link and shock adjustments. A better shock than the stock Axial AX 10 Shock? Or better than the Losi 4" shock? I have the 4 link set up on my crawler. I am not sure I have it set up right but it is on my crawler. Thanks for taking the time to reply to my post. I know it can be a pain talking to new crawlers. | |
04-06-2009, 12:55 PM | #29 |
I wanna be Dave Join Date: Jan 2009 Location: By a lake in Thornton
04-06-2009, 01:02 PM | #30 | ||
Rock Crawler Join Date: Mar 2006 Location: Holiday, FL
04-06-2009, 01:08 PM | #31 |
here's a good thread on 4 link Anti Squat and Suspension Tech |
04-06-2009, 06:18 PM | #32 |
| Overwhelmed I think I will stick with getting a new chassis vs having to read more at this time. I have learned so much that at times I feel overwhelmed with all the information. At this time all I am trying to learn to do is lower my crawlers COG. At some later date I will attemp to learn suspension geometry and squat vs anti squat informatioin. Thanks for taking the time to reply to my post.
04-06-2009, 06:20 PM | #33 | |
Thanks for replying to my post. | |
04-06-2009, 06:22 PM | #34 | |
04-06-2009, 06:28 PM | #35 |
smoothhness of articulation from the stock shocks i think it lowered it about an inch
04-06-2009, 06:57 PM | #36 |
04-06-2009, 08:09 PM | #37 |
Quarry Creeper Join Date: Mar 2008 Location: Huntington Beach
once you understand squat and anti-squat then you can tune ur rig and make it climb real well. |
04-06-2009, 08:20 PM | #38 |
| I understand what you are saying about squat and anti squat, but right now I am working on learning the basics of a crawler and how to begin to set up a crawler and what to look for as I test my crawler. As in any endeavor the basics are the foundation on which all advanced techniques stand on for support. |
04-07-2009, 08:40 AM | #39 |
| Shock Mod
Last night I finally modified my crawlers standard shock. I took out the black spacer that was inside the shock and added a 1 inch nylon spacer. This lower the shock 1/2 inch. I know I could have lower the shock more, but I am trying to experiment and see how my crawler reacts to this change before I do more modification. I am sure I will reduce the shock a total of 1 inch just for practice. I have ordered some Losi shocks and will put those on when they arrive to me. Thanks everyone for your help. My COG is still high, my crawler wont stay on its side. Any additional ideas on how I can lower my crawlers COG? I have already moved the battery (8 cell split pack) to the front axle, moved the ESC and received to the upper links, added 3 1/2 oz of weight to each rim (have to go to the LHS for more weights) and shortened the standared Axial shocks by approximately 1/2 inch (put a spacer inside the shock). |
04-07-2009, 08:44 AM | #40 |
Just jump it! Join Date: Aug 2008 Location: Cedar City, Utah
Lets see some new pics! (For ideas). You can take that plate off the top if nothing is on it. |
