04-07-2009, 12:11 PM | #41 |
Quarry Creeper Join Date: Feb 2009 Location: Richmond, VA
| Updated Pics
I wasnt sure if I should post the pics or the hyperlinks to the pics, so I posted the pics. Let me know if this is the right way to post pics. If the pics are to small you can click on the pic and it will bring up a bigger pic. I removed the battery plate. Should I take off the black braces that the battery plated was connected to and what do I do with my antenna now that I have removed the battery plate? |
04-07-2009, 12:22 PM | #42 |
Just jump it! Join Date: Aug 2008 Location: Cedar City, Utah
Looking good. If it doenst glitch with the antenna like it is i would just leave it. I had a antenna tube ziptied across the top of mine. If you have some longer links to put in place were the battery plate things were, you could switch them out. Looks like its testing time. I would run it a while, see if it does what you want. If not let us all know!! |
04-07-2009, 12:29 PM | #43 | |
Quarry Creeper Join Date: May 2008 Location: ncrccrawlers.com
There is not much more you can do man. Your on the right track. PS: you will love the 4" Losi shocks over the stock ones. | |
04-07-2009, 04:00 PM | #44 | |
What should my crawler be able to do on the rocks(go up a 45 degree incline)? I will test out the crawler today and this weekend when i am off from work. Thanks for your help. | |
04-07-2009, 04:05 PM | #45 | |
Plus, the bent links in the rear get in the way of me flipping the shocks. Any way i can correct this problem? i havent measured my skid height (i will later today), but it looks like 3 inches. Cant wait to get my Losi shocks | |
04-08-2009, 10:55 AM | #46 |
Newbie Join Date: Mar 2009 Location: New Brunswick, can
| lowering COG
[quote=MattH;1720175]You're off to a good start. Try adding stick-on weight to the inside of your wheels. You'll have to take the rims apart, but it's well worth the effort. Add 7 oz. to each front rim and 2 oz. to each rear rim. Some guys use far more weight, but this place to start. a better way to do this is by putting small ball bearings in the rim insted of weights. this way you will always have the weight of the bearings at the bottom of the tire as they move. |
04-08-2009, 06:30 PM | #47 | |
[quote=meaney;1726089] Quote:
04-09-2009, 11:41 AM | #48 |
| Ideas?
Anyone with any additional hints or tips to help lower my crawlers COG or improve its performance in general |
04-09-2009, 01:24 PM | #49 |
I wanna be Dave Join Date: Jan 2009 Location: By a lake in Thornton
all the main points are covered in this thread.... alluminum rims, split packs, re-mounting electronics, susp. and link geo. when understood and applied to any crawler, increases capabilities. then its all trial and error, drilling, dremmeling fabbing and beer! |
04-09-2009, 01:42 PM | #50 |
| Ground Clearance I took my crawler out today and was surprised at how much better it crawled over rocks. I was able to go over rocks that had stopped me previously. I just have to be careful of what line I take due to the lower COG. Now I am considering getting taller tires to raise my ground clearance. My question is will this mess uo my COG?
04-09-2009, 04:41 PM | #51 |
Rock Crawler Join Date: Sep 2007 Location: Colorado Springs
It will change your COG. MIght not completely mess it up, but will change it. The one thing with crawling is change one thing at a time, test. If you like like it leave it alone, if you don't change one more thing. Test repeat. You will soon learn that you can't tune a rig to do everything perfect. It will do climbing well, but not so good on break over stuff. Change something and now you can't climb but will do break overs. That is why you will see guys with two sets of rims and tires, another set of shocks. They will change for comp location or even per course. It took me about 4-5 months to get my shafty dialed where I needed it. One other important thing to remember is to tune your rig to your driving style and rocks, only you know how to do that. I think most people overlook that. Good luck, happy tinkering and welcome to the crack addiction!!!
04-09-2009, 06:00 PM | #52 | |
04-10-2009, 04:59 PM | #53 |
| Updated PIcs
Here are some pics of what my crawler is able to do after the upgrades suggested in this thread. I couldnt video with one hand and drive with the other so I just took pic at the top of the rock. |
