04-11-2009, 09:48 AM | #1 |
Quarry Creeper Join Date: Feb 2009 Location: Richmond, VA
| Help - Lost Drive Shaft Screw
While running ny Axial crawler yesreday I noticed no movement from my rearwheels. On closer inspection I found my drive shaft had come loose from the transmission. Even closer inspection reveal that the screw (AXA180) was missing from the rear yoke (AX 30380). Does anyone know where I can get another one of these screws (AXA180)? I have tried Lowes and Home Depot without success. Any help with this problem would be appreciated. Yes, now I know to use thread lock on these types of screws. |
04-11-2009, 10:28 AM | #2 |
RCC Addict Join Date: Nov 2008 Location: Greece, sun, sea and rocks
It is a simple 3x3mm set screw. Set screws are hard to find in hardware stores. Try going to your LHS and ask for a similar screw. If they don't give one for free I am sure they can give you a pack of assorted screws that will do the job plus you will have spares. It wont cost you more than 5$ I guess.
04-11-2009, 10:36 AM | #3 |
RCC Addict Join Date: Jan 2009 Location: Sebastopol CA
If you can't find them locally Mcmaster.com has them in 100 packs for about 4 bucks. |
04-11-2009, 11:10 AM | #4 |
04-11-2009, 11:12 AM | #5 | |
Unfortunately my LHS is 30mins from my house and I cant get to them until sometime next week. Have to work and LHS in the other direction:-( | |
04-11-2009, 11:23 AM | #6 |
Well,if you can't get to a hobby shop,order on line or poop one out,you could cut a 3mm button head bolt down and use that. I've done the same and it works fine. Thread a 3mm nut on the bolt before cutting. After cutting,remove the nut and it'll clean the threads up at the cut.
04-11-2009, 11:24 AM | #7 |
Rock Crawler Join Date: Jan 2006 Location: Phoenix
04-11-2009, 11:35 AM | #8 |
Rock Crawler Join Date: Sep 2008 Location: N.E. Mpls
Ace hardware might have them....Or possibly a fastener supplier... I get 90% of my hardware from a fastener vender... |
04-11-2009, 02:32 PM | #9 | |
04-11-2009, 02:33 PM | #10 | |
| Quote: | |
04-11-2009, 02:34 PM | #11 |
04-11-2009, 02:39 PM | #12 |
Rock Crawler Join Date: Jul 2007 Location: clearfield
04-11-2009, 03:51 PM | #13 |
Rock Crawler Join Date: Mar 2009 Location: Victoria BC
04-11-2009, 03:55 PM | #14 |
to help with them coming off i put a grub screw in each side of the yoke (2 per yoke)
04-12-2009, 07:45 AM | #15 |
04-12-2009, 07:45 AM | #16 |
04-12-2009, 07:47 AM | #17 |
I got a screw cut down and put my drive shaft back together and this time I used Loctite on the screw. Thanks for all the replys |
04-12-2009, 07:53 AM | #18 |
Official Cook of the ECC Join Date: Dec 2005 Location: Hawthorne, Florida
04-12-2009, 09:30 AM | #19 |
