| | #1 |
| Rock Stacker Join Date: Dec 2008 Location: Marion, iowa where no fun happens,ok, maybe once in a long while!!
| just what the title says |
| Sponsored Links | |
| | #2 |
| Rock Crawler Join Date: Mar 2009 Location: Victoria BC
| droop is when the shock is fully compressed at ride hight (just sittin on a flat table) it lowers your COG, its just a different suspention set up so rather then your shock compressing to articulate on the rocks, it will be extending. basically take your spring off your shock and then you have a droop set up, how ever you will need to tune it with thicker oil, / internal springs limiting it with fuel tube to set your right hight, or chaning upper moutning locations if you want to get it to work decently. if you use search you will come up with a ton of info thats more in depth then i am going heres a thread thats got the basics of settin up droop in it Edge chassis help Last edited by ultimate_monkey; 04-18-2009 at 09:08 PM. |
| | #3 |
| kool thanks |
| | #4 |
| Quarry Creeper Join Date: Jul 2006 Location: Apple Valley, CA
| | #5 |
| Quarry Creeper Join Date: Feb 2009 Location: Richmond, VA
| What is the benefit of having a droop or internal spring set up? Will droop lower a crawlers COG and/or its ground clearance? I am trying to lower my COG without affecting my ground clearance. Thanks in advance for your time answering these questions. The link posted earlier was a big help in answering most of my questions. Last edited by BMFOTP; 04-19-2009 at 09:21 AM. Reason: found info |
| | #6 |
| the only differance between external spring and internal sprung is where the spring is, about all you gain is some clearance around the shock, but when you go to droop you will lower you COG and loose GC. they kind of go hand in hand. if you want a lower COG and keep your GC you will have to do things like get ur battery on your axle, add wheel weights put your electronics on your links or an axle plate, flip your shocks basically get any thing you can down lower then it is now |
| | #7 |
| Quarry Creeper Join Date: Feb 2009 Location: North Bend
| How much ground clearance do you have right now? how much do you want? Most comp crawlers that i've seen run between 2"-2 3/4" of ground clearance depending on the driver. My setup is running at 2 3/4" and I think it just the amount of ground clearance. Last edited by legion1capone; 04-19-2009 at 01:09 PM. |
| | #8 | |
| | #9 |
| Not really worried about comp crawlers. Have no intention of ever trying to get to that level in this hobby. I am just trying to get a sense of what is a reasonable ground clearance. My crawler at present has 3" of ground clearance. Which is good for here in NC. I will probably drop my crawlers ground clearance a little once I get my Losi shocks. |
| | #10 |
| no problem, i'm running full droop and i have about 2 1/4" GC, when i had the stock chassis, i run full droop with about 1/4" of fule tubeing on the shock shaft on the out side, and had about 1 7/8" of GC, useing 1 pen spring inside each shock. and i found it much better then running a spring set up, its alot of playin around and tuneing to find what works for you, |
| | #11 |
| Newbie Join Date: Oct 2008 Location: Bowling Green, KY, USA
| great topic, I'm also interested in running droop with the stock AX10 shocks and chassis. The only thing that is holding me back is Ground Clearance. I would like to at least get 2 inches preferably 2.5. |
| | #12 |
| drill mounting holes lower on your chassis this will allow you to mount the shock lower which will move the chassis up, you will need to put 6mm spacers between the shock and frame to kee the shock body away |
| | #13 |
| interesting! Will look into it! |
| | #14 | |
| | #15 |
| easies way would be, install shocks on axles, put somthing under your belly at the hight you want, then with the shock being installed at the axle end it will basically find where it wants to be on the frame by it self, all you have to do is move it around to get it in a good spot, mark 1 hole, drill it, clamp both chassis plates togeathger so they line up perfectly (yes you have to strip down your truck at this point" use the 1st hole as a guids and drill the hole onthe other plate, unclamp them and flip the top one left to right, reclamp and drill 2nd set of holes, thie will make sure all 4 holes end up in exactly the same spot on the chassi |
| | #16 | |
| Thread Tools | |
| Display Modes | |
