Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: where can i get the tube?
Old 04-21-2009, 10:20 PM   #1
Default where can i get the tube?
http://www.shop.rpphobby.com/images/...-813397535.jpg
the chassis the square frame where do i get it
findcheaptruck is offline   Reply With Quote
Old 04-21-2009, 10:45 PM   #2
What....... what?
2JSC is offline   Reply With Quote
Old 04-22-2009, 06:22 AM   #3
if yer talking bout the tube frame, it's 3/16" brakeline from any auto parts store.................bob
bob1961 is online now   Reply With Quote
Old 04-22-2009, 08:54 AM   #4
And the chassis appears to be solid square stock... 1/4x1/4"
For the brake line (3/16") try to get the stuff that doesn't have any coating.
If you have a NAPA auto parts store near you ask them if they will sell it at shop price...it'll save you a couple $$ a piece (6ft.)
shierkahn is offline   Reply With Quote
Old 04-22-2009, 09:57 AM   #5
in the event that someone cant find the noncoated line, what is the best way to get the coating off?
crawlinlosi is offline   Reply With Quote
Old 04-22-2009, 10:13 AM   #6
I'm Dracula, Bitch.
JeremyH's Avatar
Acetone.
JeremyH is online now   Reply With Quote
Old 04-22-2009, 11:04 AM   #7
once i had the pieces cut to size i chucked it in my drill and ran it on high speed with some plumbers sanding cloth that looks like window screen with grit....took bout 10 minutes with a 24" piece to clean it off........bob
Old 04-22-2009, 03:37 PM   #8
Shut up Dave
jetboat's Avatar
northernautoparts.com you wont find it any cheaper
jetboat is online now   Reply With Quote
Old 04-24-2009, 11:34 PM   #9
Ace hardware usually has an awesome selection of thicker walled stuff. Brake line is too weak. I tried my first rig out of brake line and every good fall would dent and bend it. Switched to a little thicker walled steel and I can probably drive my F-150 over it.
J-Rock is offline   Reply With Quote
Old 04-25-2009, 12:51 PM   #10
Doin time....
Blazefighter's Avatar
I never thought of Ace, what part of the store do they sell it under?
Blazefighter is offline   Reply With Quote
