Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: Delrin ??
Old 04-28-2009, 10:54 PM   #1
I joined the Band!
Default Delrin ??
Where do I buy it? Does it have to be ordered?
Thanks
outofreach is offline   Reply With Quote
Old 04-28-2009, 10:56 PM   #2
www.mcmaster.com for starters. Boedecker plastics is another one. I can keep going but it's easier to let your fingers do the walking!
Sydwaiz is offline   Reply With Quote
Old 04-28-2009, 10:58 PM   #3
I joined the Band!
Thanks for that
Do any hardware stores it? I would like to pick it up and not order it.
Old 04-28-2009, 11:12 PM   #4
Ridout Plastics on Ruffin Rd I know has White and Black Delrin
Port Plastics probably will
Not sure what part of San Diego you are from, but if you just put google map near your hosue and serch "Plastic" you should be able to find something good.
Hope you find some good stuff!
FDAapproved is offline   Reply With Quote
Old 04-28-2009, 11:56 PM   #5
downtown's Avatar
Yours is on its way FDA
Outareach-Rid out is where I started buyin my stuff at first. There are several suppliers in SD..
Mcmaster is your best bet for some small stuff as well.
PM me with what you might need, and Ill see what I can do for you.
downtown is offline   Reply With Quote
Old 04-29-2009, 07:52 PM   #6
Rcbros have 12" 1/4 tubes
http://www.rcbros.com/cart/Scripts/p...?idproduct=359
boom stick is offline   Reply With Quote
Old 04-29-2009, 08:16 PM   #7
ElChupoCabre's Avatar
us plastics
ElChupoCabre is offline   Reply With Quote
Old 04-30-2009, 09:50 AM   #8
Moonbuggy Berg
treday619's Avatar
Thanks
You could also check out Marshalls Industrial they are on Production Avenue in San Diego. If you need their number PM me and I will give it to you. I actually use 5/16" Delrin to make my lower links
treday619 is online now   Reply With Quote
Old 04-30-2009, 07:27 PM   #9
I joined the Band!
Thanks for the help
Old 05-05-2009, 01:10 PM   #10
Black Label Crawlers
Jeepial's Avatar
SMALL PARTS!! They have stuff on Amazon and the also have a website!They are cheaper than pretty much everyone I have found on delrin,plus they also have the largest selection of delrin rod,plate and various other plastics..Not to mention they have everything you can think of for metals and EVERYTHING...So much you just gotta check out their site...Plus they have top notch customer service.
http://www.smallparts.com/
P.S. Look under Acetal for delrin.
Jeepial is online now   Reply With Quote
Old 05-05-2009, 06:18 PM   #11
chevellian's Avatar
Bookmarked
Great prices, great selection!
Nice find Jeepial, thanx
chevellian is offline   Reply With Quote
Old 05-05-2009, 07:07 PM   #12
Jeepial's Avatar
Originally Posted by chevellian View Post
Bookmarked
No problem man...That's what I am here for...
