Go Back   RCCrawler.com Bulletin Board > RCCrawler General Tech > Newbie General
Thread: stock 27t
Old 04-29-2009, 07:34 AM   #1
Default stock 27t
with the stock 27T motor in the axial scorpion and the 14 tooth gear,If I put a 55T motor in will it not go faster? I don't want it faster.or does it give it more torque.Thanks.
camh is offline   Reply With Quote
Old 04-29-2009, 07:58 AM   #2
I dont know if it will make it faster, but I know it will have alot more torque
soundcolor is offline   Reply With Quote
Old 04-29-2009, 09:36 AM   #3
On the lookout for Rocks
constantmotion's Avatar
It want be faster, but you'll have more low end control and more torque.
constantmotion is offline   Reply With Quote
Old 04-29-2009, 09:51 AM   #4
the 55T will make it go slower, not faster. The fewer turns in the moter, the faster it will run.
syber70 is offline   Reply With Quote
Old 04-29-2009, 01:27 PM   #5
Ya want a fast motor with plenty of torque??? Get a Holmes 7T puller motor....
That should get the job done...
nonstopboost is offline   Reply With Quote
Old 04-29-2009, 01:59 PM   #6
mjh
I just threw a 19t epic in to my trail truck last night and keep it geared low....It has more speed and enough umph to get over stuff still
mjh is offline   Reply With Quote
Old 04-29-2009, 07:17 PM   #7
Default 55 turn Motor
The 55 turn motor will give you more low in power and better control over your rig during crawling.
fernando is offline   Reply With Quote
Old 05-19-2009, 01:20 AM   #8
I have a RTR and switched to a 55t motor the 27 was to quick to use crawling anything.
scrapen is offline   Reply With Quote
Old 05-19-2009, 10:17 AM   #9
it will also get the job done of frying his stock electronics.. but dont get me wrong that is one badass motor ;)
resetpunk is offline   Reply With Quote
Old 05-19-2009, 10:51 AM   #10
Ya could also just get a smaller pinion/larger spur to gear that 27t down. Than when ya upgrade to 3s and a good esc ya will allready be set for a good 35t handwound. All the cheap motors put out about the same power, just at different speeds.
oldhippie is offline   Reply With Quote
