05-29-2009, 03:28 PM | #1 |
Rock Stacker Join Date: Apr 2009 Location: west sacto
| antenna touch
just a stupit question i know but i would like to know that when i switch over to a 2.4ghz controler, is there going to be a antenna wire comming out of the reciver, and if there is, is it still important not to have the wire touching its self for interfearance. or will it hurt it if i cut the wire down a little.thanks.... i told you guys it was a stupid question |
05-29-2009, 06:49 PM | #2 |
Rock Crawler Join Date: Mar 2009 Location: Cottontown
Yes, but its very small, I think about 18 gauge size. shouldn't be a problem at all with interferance. As for cutting down the wire, I dont think you'll have to do that, there only about 2.5 to 3" long |
05-29-2009, 06:52 PM | #3 |
Yeah, it's even shorter than... too easy. But they're short and you can tuck 'em in just about anywhere.
05-29-2009, 06:59 PM | #4 |
| I put mine inside a short section of antenna tube...... My receiver is mounted on the front axle and the antenna itself is zip tied to the left front upper link.
05-30-2009, 09:58 AM | #5 |
RCC Addict Join Date: Jun 2008 Location: Fresno
in my crawlers i actually just shove the antenna into rx caseing if i have a lil extra time on my hand it open 'er up coil it around the bottom of the rx's circuit board inside the caseing. havent had any problems yet. no interference no shorts, and imo not a major difference in range |
05-30-2009, 10:20 PM | #6 |
Who's your Daddy-0! Join Date: Mar 2008 Location: Augusta
Don't cut the antenna on a Spektrum RX! Not all of them are short either. The antenna on my SR3100 is 7-8" long! I just coil it up and zip tie it up. I haven't had any trouble.
06-03-2009, 03:03 PM | #7 | |
Rock Crawler Join Date: Jul 2008 Location: Port Angeles
Spektrum rx's use "tuned" antenna so cutting is very very bad thing. I coiled mine up inside the receiver box and it works like a charm | |
06-03-2009, 03:23 PM | #8 |
In my scale rigs I coil up the antenna and put in the the box with the RX. On my comp rigs I use a short piece of antenna tube zip tied to the chassis. The wire is smaller gauge than AM or FM and much shorter (on my SR3000 and SR 3001's) so no need to cut them. 2.4GHz is much much more forgiving about antennae placement than AM or FM. |
06-03-2009, 06:31 PM | #9 |
Rock Stacker Join Date: Jun 2009 Location: Buford, Georgia
| Do not cut the 2.4 antenna wire....the radio brand does not matter. Harry |
06-04-2009, 08:48 PM | #10 |
Rock Crawler Join Date: May 2009 Location: Welderville just south of benchviseland
The wire on my new Futaba 6exa is about a mile and a half long. I may have to try the coiling up in the RX box trick. I like that idea a lot. Things that stick up on vehicles that flip over is a bad idea...as well as slicing the wire on your receiver...I accidentally pulled that stunt on my nitro many moons ago...Which has inspired me to carry an extra receiver lol.
06-04-2009, 09:12 PM | #11 |
I wanna be Dave Join Date: Mar 2008 Location: Wayne county. PA
i made up a plastic plate to mount my 3100 rx on and to hold the wire....if i ever need to remove the rx it comes out all in one unit attached to the mounting plate....plus it looks cool like a little wipe antenna ;) .............bob .... |
06-04-2009, 09:26 PM | #12 |
RCC Addict Join Date: Jan 2009 Location: Sebastopol CA
I put my aentenna inside a length of fuel tubing and zip tied it to the chassis. With 2.4ghz you can put it anywhere you want from what I understand. |
06-04-2009, 10:42 PM | #13 |
Quarry Creeper Join Date: Jul 2008 Location: Erin, Ontario, CANADA
Quoting directly from the Spektrum 3000 manual at http://www.horizonhobby.com/Products...ProdID=SPM1200 : "NOTE: If desired, the antenna may be shortened (cut) to exactly 3.6" with negligible loss of range and in some applications the short 3.6" length will make installation easier." Copied direct from the SR3100 support page at http://www.horizonhobby.com/Products...odID=SPMSR3100 : SR3100 DSM2 3CH Receiver:Surface Bulletins Spektrum SR3100 Antenna Bulletin Spektrum SR3100 Antenna Bulletin Spektrum’s SR3100 receiver (included with the DX3R) features a coaxial antenna. Do not cut the antenna. The exposed area at the tip of the coax is the functional part of the antenna and must remain at 31mm in length. Altering the 31mm length will detune the receiver reducing range. Avoid sharp bends, pinching, smashing or cutting the coax (covered gray section) portion of the antenna. The coax is susceptible to damage and if severed, or if the insulation is damaged, reduced receiver performance can result. If you should damage the coaxial antenna replacement is necessary and easy. New coaxial antennas are available SPM9005 and snap onto the receiver board.Narly1 |
