07-30-2009, 09:45 PM | #181 |
Rock Crawler Join Date: Jun 2009 Location: SF
| WTF??? Dude, where did you find out how to run duals on an m11??? I love my m11 and can't for the life of me mix dual esc's with it, I can mix all the brakes I want but even the airtronics tech guy told me it can't be done!!! If it can be done why the hell did I just order a dx6i??LOL |
07-31-2009, 01:03 AM | #182 | |
Newbie Join Date: Jun 2009 Location: Chula Vista
I tweeked it a little so that I can use the dial for trimming the amount of mixing. That way I can dial power forward/aft. | |
07-31-2009, 01:19 AM | #183 |
Rock Stacker Join Date: Jul 2009 Location: worley/boise as of aug 20
hey i wanna go to a tubber on a ax 10 but i run a 7 cell bat. with the hump will the edge one fit or any thing dif. thanks |
07-31-2009, 01:44 AM | #184 | |
I have a edge tuber for ax10 I dont want anymore...let me know what measurments you want from it, it's not attatched to anything now...Ummm, i think this is a Berg thread, PM me. | |
07-31-2009, 01:50 AM | #185 |
thanks man i will pm you tomorrow with all the stuff.
07-31-2009, 02:35 AM | #186 |
WOOPOOW!! Join Date: Nov 2008 Location: Atlanta, GA
07-31-2009, 02:38 AM | #187 |
thanks man do you know off the top of your head if the hump pack will fit in there
07-31-2009, 02:40 AM | #188 | |
http://www.tcscrawlers.com/TCS-Crawl...r-p-16948.html I used to run them on my axial and they did amazing. Mount em to yer axle on either side of your servo. There out of the chassis, moving the weight up front, and also cleaning up your electronics | |
07-31-2009, 02:49 AM | #189 |
thanks man big help |
07-31-2009, 02:54 AM | #190 |
You just need to remember, they are 2/3 amp cells. So you will need to charge them on less than an amp. If you only have a charger that can charge 2-4 amp I advise to either get a new charger, or try to find a different battery. They will take a 2 amp maybe 4 times, then start popping, and soon they get HOT... and start smoking... and quit on you in the middle of a comp while your doing really good |
07-31-2009, 02:31 PM | #191 |
ha thanks sounds like you been there one time |
07-31-2009, 04:36 PM | #192 |
Quarry Creeper Join Date: Mar 2008 Location: Zachary
07-31-2009, 07:19 PM | #193 |
Newbie Join Date: Jul 2009 Location: Central Coast
does anyone know how to build an "axle sitter" battery out of a regular 7.2 6-cell?
07-31-2009, 07:23 PM | #194 |
and also, the steering servo on my rtc is WAY underpowered, anyone have a capable servo that can run off a Nicd setup?
07-31-2009, 07:27 PM | #195 |
08-01-2009, 06:57 PM | #196 | |
Rock Crawler Join Date: May 2006 Location: Georgia
They are a little more expensive but are well worth the money. I have been running 2 of them for the last 18 months without problem. I have wasted more money on servos than anything else. In a years time I went through 2 Hitec 5645's, 1 JR ST125MG, and 4 Towar Pro 995's. If you plan on staying in this hobby for a while or competing go ahead and spend the money now or you will regret it. | |
08-01-2009, 07:09 PM | #197 |
Yeah, having a good servo is definetly a thing that will help you tremendously. Im so used to running the crappy stuff in comps that driving my berg with something like my HS-5955 which is basically the CS-170 (The 5955 is discontinued) Is SO amazing! I absolutley love hearing my berg knuckles hit my axle case Last edited by Colby; 08-01-2009 at 07:11 PM. |
08-02-2009, 12:20 AM | #198 |
Pebble Pounder Join Date: Jul 2009 Location: Colorado
Couple of serious noob Q's: 1. What is the difference between (or definition of) "comp rig" vs "basher"? It seems clear enough and I *think* I know, but you know what they say happens when you assume... 2. If one was to add both a front and rear dig to, say, an ax10, would one require a 4 channel radio? Or is there a way to make it work with just 3 channels? Thanks. \oo/_ _\oo/ Last edited by nathanotis; 08-02-2009 at 12:23 AM. |
08-02-2009, 12:28 AM | #199 |
A comp rig is a rig designed to compete against other people/ rigs. A basher is just something you build that doesnt really have any kind of meaning, you just built it to have fun with. You do not need a 4ch radio for an ax-10 dig. you can just use a 3ch radio with a 2 position switch |
08-02-2009, 01:46 PM | #200 |
hey got a ? what is a good shock to go to from stock thanks
Tags |
axial, berg, help noob, whats a dig?, whats clod stall? |
