![]() | #21 |
TEAM MODERATOR ![]() Join Date: May 2004 Location: Tennessee
I think this is a cool thing for Colby to do. This section is here to help the newbies,Colby is trying to do that. The next guy to steer away from the topic or try to start a flame fest in here will get an infraction. ...Now,back to the topic..... |
![]() | #22 |
WOOPOOW!! Join Date: Nov 2008 Location: Atlanta, GA
Thanks rapt....reflection ![]() Brandontodd33 is still under my wing. Who else needs help? I will start a newb familly! |
![]() | #23 |
RCC Addict Join Date: Apr 2009 Location: Anderson
Colby, you could be the Newbie leader on the forum!! Just think, you could be a god to some people!! -Jason |
![]() | #24 |
Haha, yep thatd be cool! Brandontodd33 has gotten set on the right path. NEXT NEWBIE!! ![]() |
![]() | #25 |
BUMP! That guy wasnt even a berg newbie, ill help anyone. Freakin bored....
![]() | #26 |
Quarry Creeper Join Date: Dec 2007 Location: Central Florida
this is cool now i wont feel so bad asking noob stuff :-) I got my 1st crawler ever it is the MRC and the torque twist is killing me I want a MOA! So what is the most common setup as for motors, esc batt. goes?I meant like 2 esc 1batt etc. Also I have a Heli radio that I plan on using would it be posible to setup running both motors with the left stick and if I want just one running hit a position switch that way I have to use both stick, would I still be able to use the electronic DIG. thanks for your time |
![]() | #27 | |
| ![]() Quote:
Second, a MOA is definetly a big step from a MRC. Some common setups: Dual Tekin FXR esc's with a Castle BEC and dual handwounds or EPIC motors Sidewinder ESC with dig switches and servo, or PUNKRC dig switch Mamba max ESC with dig switches and servo, or PUNKRC dig switch The best setup is 1 esc, punk dig switch, and 3 pos 3channel radio and receiver. I really dont know what to say about the heli TX.. DX3R is the best thing for a MOA. Last edited by Colby; 06-24-2009 at 01:14 AM. | |
![]() | #28 |
Quarry Creeper Join Date: Dec 2008 Location: SoCal
Another fellow Berg newb here. ;) What are the main differences between a Berg axle and a Bully axle? I am trying price out an LCC and MOA rig to see which will be more expensive... what do you guys think?
![]() | #29 | |
| ![]() Quote:
![]() | #30 |
Rock Crawler ![]() Join Date: Nov 2008 Location: kansas city
OMG i didnt even get past the first post before i decided to click that magic "post reply" button. now i know i have a comp worthy rig but to get it to perform how i know it should is a different story. Ma'berg. click my link! im having a crap load of troubles and any input would be great. plz scan though it all cuz alot has been changed since he first few posts. Last edited by robbio4422; 06-24-2009 at 02:24 AM. |
![]() | #31 |
Your berg looks great!!! Whats wrong with it?
![]() | #32 |
| ![]() lets start with whats right. soo far all im happy with is the KK chassis and the MM. if i could start over with what i know works for this rig i wold scrap the rest and go another direction. most of it has been just luck. i cant seem to get my dig situation figured out. (burning servos like no other) motor crapped out at just under 4 packs ran through it.(arm went bad) i recieved the wrong shocks from the vendor i used and their customer service sucked so i took one for the team (looking for traxxas 90mm BB's). my link geometry isnt quite were it needs to be but thats something i almost have dialed in. list goes on. feel free to post on my build thread. any comments will be taken with the highest respect. it my first berg so its a learning process. |
![]() | #33 | |
| ![]() Quote:
![]() | #34 |
Any more newbies? ![]() |
![]() | #35 |
Newbie Join Date: Nov 2008 Location: Nor Cal
im a newb! i just got my axles and they r gettin gaild in and am going to the WCC
![]() | #36 |
![]() | #37 | |
Rock Crawler Join Date: May 2006 Location: Georgia
This is a great topic Colby ![]() ![]() Quote:
Another thing to consider when running 2 ESC's is that when doing a Dig the motor braking is controlled by the drag brake in the ESC. If you use the Mamba Maxx or Sidewinder the drag brakes are weak and will not lock the tires down to do a Dig. The brakes in the FXR are much stronger and will lock the wheels down to do a Dig. This problem is not seen when running 1 ESC and Dig switches because the switch if wired correctly shorts the motor out giving full braking power. I run Dual FXR's and a Nomadio React 4ch pistol radio. I don't think I could ever go back to using Dig switches. | |
![]() | #38 |
Thanks ryan. Yeah, you see as ryan mentioned if your dig switches are wired correctly, it will completely short out the motor. Eron wired my truck together because he thought it didnt need so much wiring and wouldnt short the motor, so its all rolling disconnect. I am re-doing it tomorrow. I will post up my template tomorrow for you. Could I get this thread stickied maybe? |
![]() | #39 |
Thanks Reflection for the sticky!! Who needs some help ![]() |
![]() | #40 |
So when you use the PunkRC dig switch, do you just leave the throttle spot on the receiver empty? I don't have any of the parts yet, but I'm trying to fiugre out how to wire everything. The dig switch goes into the aux/3rd channel port on the receiver, and the ESC and motors wire directly into the Punk RC dig switch? I am also assuming a single Mamba Max ESC with two brushed motors should work fine on this setup right? Thanks in advance for any help you can provide. |
Tags |
axial, berg, help noob, whats a dig?, whats clod stall? |
