06-23-2009, 06:16 PM | #1 |
Quarry Creeper Join Date: Jun 2009 Location: Fredericksburg
| Inverted shocks good or bad?
Other then lowering the weight by flipping the oil side of a shock down, are there reasons for not inverting the shocks on an ax10 or losi style shock? Venting, valve function/rate or any other problems experienced? Thanks from an ignorant newbie!:-P |
06-23-2009, 06:24 PM | #2 |
The shocks I've tried,haven't shown any ill effects from running upside down. I ran some CEN piggybacks a long time ago,seemed to work fine upside down. Twin Force shocks work fine upside down. Pede shocks work fine upside down. Jato's,seem to work fine upside down. Others,not real sure
06-23-2009, 06:31 PM | #3 |
Quarry Creeper Join Date: Jun 2006 Location: Folsom
The ones I tried leaked. I think they were Maxx and I assumed the o-rings must have dried out from not having oil around them all the time.
06-23-2009, 06:38 PM | #4 |
Quarry Creeper Join Date: May 2006 Location: York Area
sometimes the steel shaft in the shock weighs more than the oil filled plastic body and inverting it doesn't help with CG at all, it actually hurts it.
06-23-2009, 06:43 PM | #5 |
Rock Crawler Join Date: Sep 2008 Location: You will never find a more wretched hive of scum and villainy
been running maxx shocks upside down for almost a year with no leaks |
06-23-2009, 07:22 PM | #6 |
I wanna be Dave Join Date: Jan 2005 Location: Hueytown, Alabama
Big bores with no problems here.........
06-25-2009, 02:21 PM | #7 |
Quarry Creeper Join Date: Jul 2007 Location: Fort Mill, SC
We used to invert them on the RC-10, when we ran internal spacers. This kept the piston down and in the oil and allowed for even damping throughout the shock travel range. (the air rises to the top, where the piston can't go, due to the internal spacer) I inverted min on the front of my crawler to allow for alittle more space for the batter-on-axle setup. I hadn't even thought of the lower COG. |
06-25-2009, 02:27 PM | #8 |
Newbie Join Date: Mar 2008 Location: Casper
I run mine upside down, and seems to work great unless your tires are rubbing against the spring adjusters, then it can REALLY screw with your preload. |
06-25-2009, 03:40 PM | #9 |
Thanks for all the responses, I guess it will be a problem to run the new axial shocks from the rtc inverted, I beleive that they are vented, correct? Probably not good upside down with vents:-(
